Wanted: UltraMaster software
Ultra Master Software
You can download version 1.60 from Rockwell Automation website. Under "Support" you should see "Software Downloads." After clicking on that link, you will see another page with "Free Software." After clicking on that link, you will see another page with a search bar that contains the word "FREE." Change "FREE" to "Ultra" and you will see version 1.60 is downloadable in zipped format.
If you have a current TechConnect contract, you will find version 1.62 attached to Knowledge Base Article 35047. I do not know why this version is limited access.
fail-.
a problem has seen.
Software Updates
Qualify for an Update
Please provide the following information so we can qualify you to download the software.
Effective February 24, 2012 our qualification process changed and requires a company name rather than a registered user name.
Registered User Information (Company Name under which the software is registered): Company Name:* Company Name must be entered!
Software Serial Number (From the original disks) Serial Number:* Serial Number must be entered!
Note: This Software Update can only be used for this Serial Number. Please ensure all licensed copies of software are in support.
then I havent a contract or other thing similar with rockwell, it appears that I fail in my attempt to obtain the software.
thank you johnboy.
Seeking Ultra Master...
I was wondering if anyone has an updated link to Ultra Master. Trying to get the fault codes from an Ultra 100 series drive, and need the software. Many thanks!
Ola Grabriel!
Tambe estou precisando deste software, o BRU ou Ultra Master para fazer o tuning de um drive antigo.
Caso possa ajudar ficarei muito grato.
boas eu tenho o software bru master 1.51
estou com problemas para ligar a uma bru 200 dm-30d
sera que este software da para esta drive?
ou sera do cabo que tenho que nao esta bem ligado? sabe o pinout?
I'm using raspberry pi 4b to poll 3 different plcs with modbus tcp and then publish the tag data using mqtt sparkplug b back to my Ignition...
3,448
Hello, I'm struggling with getting an email to send using an eweb module on a controllogix system. Any chance I could get someone here to help?
1,856
Greetings to all ... I've never owned or needed a household generator – but current conditions have convinced me that now's the time to buy one...
23
6,871
With the Automation Directs Open Source Arduino Compatible PLC and the Open plc Project, plus all the Raspberry Pi HMI's, what are your opinions...
4,313
Attention all PLCs.net members!! As Covid-19 has put many of us factory automation folks out of work, let’s work together to help get as many of...
18
19,536
