SLC500 ownership problems
Craig@JRL
Jun 2005
Scotland
Hi Folks
Looking for a little help with comms problem to SLC503.
Sets up ok and I can see it in RS linx but when go to download a programme it say it can not get ownership of the CPU.
Tried the old battery out and short the terminls to reset it to factory standard but that does not help and I still get the same problem.
Banging head against the wall
Craig
I run into this periodically too. Both are fixed SLC500 (L40A units). Both have a PV550. These also are picky when trying to burn to store to EEPROM and that often fails numerous times in a row.
One thing I have had to do, is disconned Panelview and hook directly to the SLC with my PIC box. This usually works, but not always If not, I reboot the PLC and connect and download to the SLC as fast as possible. Not a clue as to why this all of a sudden started happening, as there have been no upgrades in software. I thought my old laptop was having issues and later found that my new(er) Dell laptop, running XPPro also has the same issue. (Was running IBM THinkpad with W95) Only thing I can think of, was RSLinx (lite) may have been updated somewhere along the line.
rPraveenkum said:
can you give me the LED status of 5/03
regards
praveen
Only LEDs that are on are ther 232 or dh485 comms ones. Tried to get access with both.
Have tried the default reset but that do not work, need to try and find a key as it is in remote setting to see if the key switch is knackered.
Can only see the 503 in the rslinx and can do an automatic check on it and it does establish comms but when try to establish comms on the rslogix I get the message as before.
252
can the slc500 5/05 send a email and text over Ethernet ?
185
Hello, did anybody know, if there exist an converting cable like the1492-CM1746-M01 (for an 1746-IB16 to an 5069-IB16), for an 1746-HSCE to an...
389
Customer is buying several spare 504 CPU's to have one handy when there's an issue with the ones in operation. Having them on the shelf for years...
2,830
You have to go offline to create the 'Trend' but do you have to download the program to go back Online with the Trend ?
343
