SoMachine Logic Builder Simulation
jara
Jul 2010
Cordoba
100
Hello Everybody.
Can I simulate with SoMachine Logic Builder the network Modbus TCPIP?
With UnityPro and the new version Control Expert it is possible with the PLC Simulator, but with SoMachine I can´t do it.
I have setup everything, but the warning is like the picture.The bus is not running. The shown values might not be up-to-date.
Any tip will be gratefull
Thank you very much for your time.
Regards
I don't think it will work in simulation.
After many hours of trying I managed to make it work using Codesys Control Win SoftPLC running as Modbus Client and Ananas as Modbus TCP Server on the same PC.
I don't remember if Somachine has a SoftPLC which can be used for testing and debugging purposes like vanilla Codesys. Will have to wait until next week after the Easter holidays when I come back to work.
Hi kallileo
Thank you very much for your answer.
I have spend the last days trying to simulate, but without luck.
I don´t have find any documentation about this issue.
Yes, SoMachine has a SoftPLC as Device, I have tried with this device but I wasn´t able to comunicate in the same machine with Modbus Tester from schneider.
https://www.schneider-electric.us/en/faqs/FA180037/
I will waiting to the next week if you have more information.
Thank you very much and enjoy Easter holidays
Best Regards
I am trying to connect with a Schneider plc which has a firmware version only available in Somachine v4.2. In Machine expert After taking upload...
100
Hello dear experts, I incurred in an anomaly while working with HMISCU devices by Schneider. I downloaded the program and everything seems to...
431
Configuring a PWM block for servo control in SoMachine today and was attempting to run in simulator to test some loop controls, will PWM output...
918
Hi all, I've been trying to develop modbus rtu program between uv balasts and plc ı'have 6 slave balast.I am reading fault run voltages etc...
1,189
Hi, i don´t get why my coil doesn't activate when the contact it´s true. I'm new to PLC programming, this is my first project. I'm attaching...
1,483
