Citect to Modicon via Modbus
Jul 2007
Kiruna
600
Hi there,
Firstly I no nothing about Quantum PLCs and very little about Citect.
I have an old Win NT Citect SCADA system failure which I need to replace quickly.
I have the backup and have managed to restore it to Citect 7.2 which I'm told will run on Win 7 PC.
The communications board type in Citect is BOARDX and the IODevice is Modbus.
Without physically seeing this machine (its abroad) I'm guessing its using a standard onboard serial port for communications and not a dedicated comms card.
So what are my options giving I'm inexperienced with both Citect and Quantum PLCs?
Here are my thoughts...
1. Buy a PC with a serial port. Probably hard to find nowadays
2. Buy a PC and a USB to serial adapter
3. Install some sort of Ethernet module on the quantum PLC. - Driver and probably tags have to be reconfigured in CItect.
4. Install some sort of gateway -Serial to Modbus TCP/IP .
Hi there,
Is it RS485 or RS232 ?
Either way Modbus Gateway is probably the easiest option, just use the Schneider EGX150, works well, then just change the comms in the Citect project to be Modnet, there is a specific version of Modnet for Quantums.
I'm not sure. I cant find this information in the Citect project. It just says Modbus. I havent been to site.
If I use the EGX150 I just need to change the driver in Citect? Nothing on the PLC side? I don't even have software for Quantum PLCs?
Any thoughts on the USB-Serial convertor option?
Shouldn't need to change anything in the PLC end, if Citect has access to the registers now then a gateway will
If you don't know what serial comms its on which adopter are you going to buy ? If you have the Quantum project then you should be able to see what comms cards it has fitted or do you not have that either ? Possibly get a photograph of the quantum rack to see whats fitted ?
The EGX can be RS232 or RS485, should be a fairly simple job if you go that way.
I have a photo of the Quantum rack but without ever using this brand of PLC I don't know what I'm looking at.
What software is used (around late 90s) to open such a program?
Post a photo of it, i will be able to give you the best guess. Software could be Concept.
But like i say, the Quantum shouldn't need to be modified
That would be great. Seems to be a problem with uploading pictures though. When I add the attachment I get the following error:
The message you have entered is too short. Please lengthen your message to at least 2 characters.
Just make the message longer ? Or private message it to me.
Hi all, I'm running into an issue with a Modicon M340 PLC Clock and daylight savings time. I found an old thread that wrote out specific code...
1,866
I am sory because I am newbie. Can vijeo citect communicate to PLC Schneider Modicon TM221CE40R? Because I can't found it from express wizard in...
1,129
Hi Gents, this is a tricky one. I am waiting to receive an actual Modicon M340 PLC, but I would like to test my code. Is it possible to connect...
5,163
Hey there all! First of all, i really enjoy this forum. Allways friendly people to help beginners like myself! :D This is my first Modicon...
12,351
Hi all, I'm working on a projecct that connect's Vijeo Citect to several M340 plcs. To program the plcs I use Unity PRO, the program format is...
9,489
