Well this is a first... Siemens LOGO on Linux, MacOS and Windows
cardosocea
Nov 2016
Fields of corn
2,631
I was just now looking for the Siemens LOGO programming software as I have a project coming up to modify a program with one and on the Siemens download page find that it is now available for Windows, Linux and MacOS.
https://w3.siemens.com//mcms/progra...-module-logo/demo-software/pages/default.aspx
This must surely be a first in the world of Automation, no?
I understand it makes sense, particularly for the small automation range, but it's a first for me.
Do you guys know of any other automation software available for other OS's other than Windows?
I've used SCADA systems that supported many platforms, but never automation. Of course, they do it via Java, which usually means a million other problems....
Granted it's not ideal... but it's better than nothing and ahead of other brands.
This being said, Microsoft has Visual Studio for MacOSX. I wonder if their Connected Components range would be easier to port to other OS's.
Microsoft have Visual Studio Code for Linux.
Hopefully now a lot of embedded devices use Linux, we will start to see manufacturers move into the Linux space. CoDeSys would be an ideal port to Linux. Wago have controllers running a stripped down Linux system too.
This is definitely not Windows based...
ABB Advant Master (MasterPiece) runs on HP Unix. There's still new controllers being manufactured in this range even though it's "kind of" old.
That is correct, Wago is one of the vendors that have controllers running Linux. There is also a codesys runtime for the Raspberry Pi (which runs Linux), allows you to program it with Codesys 3.5. Not as robust as an industrial PLC mind you, but very nice for learning.
But all of these are cases where the PLC runtime is implemented on a Linux controller. The development software is only available for Windows though (e.g. straight CoDeSys or vendor specific versions like Wago E!****pit, Twincat from Beckhoff).
LOGO!Soft Comfort is a Java based Software and Java runs on Windows , linux and MacOS .
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
281
Hi Lads, I want to implement a flood prevention system with my domestic water pump. The intention is to have the water pump cut off on a daily...
1,067
We need a Really Simple and Cheap controller that has a display or a Web Interface where we can change some set points. We were thinking about a...
1,031
hello i have LOGO! 12/24RCE and i am looking for a schematics of electronic board. Or if someone know what is the burned component on the photo.
1,397
Hi, I'm no expert in PID regulating so I need some advise. I have a VFD controlled deepwaterpump that is maintaining the pressure in a closed...
24
11,893
