[Profibus PA] Number of nodes
luccass
Jun 2009
UK
56
Hi guys!
Could you help me a litle bit, please?
Every independent specs regarding Profibus PA says, that maximum number of nodes per network is 32.
There is a Profibus DP/PA Link module that creates ONE PA subnet and spec says, that max allowed number of nodes for PA master system is 64.
Can anyone ever tried to put more than 32 nodes under one siemens DP/PA link? Just want to double check :)
Thanks!
True, this is a Profibus PA limit (electrical).
Also true, but this is on the software level. You still need PA couplers to supply the power after the link and they have a limit of 32 devices (ideal ideal conditions) per segment. So for 64 slaves you need one of those links and minimum two couplers. If you use a Pepperl and Fuchs link you can even use all 126 addresses (minus the master ..) on one link.
Thanks! Exactly what I was thinking :)
Is there any way to get diagnostics info on device connected over Profinet/Profibus (communication with device fault) from PIW assigned to that...
2,488
Simocode DP is ship with node number 126. That node number is over node number of profibus DP (Max = 125). How can we change default node number...
5,030
Hi, I was noticing that Profibus connectors have 2 ports on them that can house 2 separate cables. Can I use 2 cables with Profibus signals...
174
Hello, I am in possession of a WAGO PFC 200 750-8216 which I was successfully able to set up as a Modbus RTU Master to a slave device using...
78
I am trying to implement a profibus network and am a newbie in the automation and communication industry. what are the components required for the...
101
