Load Cell application please help Continued
khaledgenidy
Dec 2017
usa
I have few questions regarding analog input. and i was wondering if you can direct me.
i was able finally set my cards and connect my load cell to my analog input where it outputs 2mV/V for 1k.
With the following specs i am powering the loadcell with 12V 1A
It runs from 10V to 15V
Load Cell info:
https://www.omega.com/pressure/pdf/LC8200.pdf
PLC Info:
Analog Input 1769-IF4
I also was able to get to the point to get the values as the instruction refereed me in the manual for 1769 analog if4
http://apps.watersurplus.com/techlib..._user_D599.pdf
page 21
after this step i am not sure how to make the formula or the linear equation to calibrate these values.
Do I have enough excitation voltage?
Do i start from the ladder logic?
What Element ex.(MOV, DIV) to use regarding linear equation?
Your loadcell produces a millivolt signal. Your PLC input card expects a milliamp or voltage input. I suggest you purchase a load cell amplifier with a 4-20mA output in order to bridge the signal gap between the two devices you already have. Or buy the Hardy Instruments load cell module and use it for a direct connection between the load cell and the PLC.
Hello, I have an in-line (compression-20k)load cell installed on a vertical hydraulic press. The cylinders stroke is checked at home or fully...
5,331
Hi guys, I am doing a new app that involves web tension measuring, I have load cells now and I think this is the best method for this. I have...
2,380
Dear All, I am working with a Load Cell project. The auto packaging machine will weigh the product for 15kg. When 15kg is reached, the dough input...
17
11,783
Good Afternoon, I’m limited with a skilled maintenance staff to design and build Load Cell , Rollers , etc. for conveyor sections . Do...
660
Good Afternoon , Does Rockwell Automation have an Input Card , maybe in the 1734 series , or CompactLogix series that will receive signals...
840
