Logix 5000 First Scan Bit
russrmartin
Aug 2002
Eastman, Wisconsin
744
I know that to get the first scan bit out of a CL5000 processor, you need to use a GSV. But that is as far as I get. I cannot find the actual first scan object. Can anyone tell me where to get this, or post a screen shot of a GSV in which they got this bit? Thanks.
Russ
Gerry is right. Browse the on-line help for "Monitoring Status Flags". You'll find several S: flags, such as S:C for carry, S:N for negative result and S:MINOR for detection of minor faults, besides S:FS for first scan.
Kind regards,
Thanks guys! I was wondering about that, too!
Especially since the "power-up" routine is exactly that. Don't expect the power-up tasks to get executed unless you unplug the controller. Switching from Program to Run doesn't do it.
AK
Hi, can anyone explain me what is the difference in Logix Designer FBD between instruction first scan and instruction first run? I understand...
2,561
Ok so this sounds really simple but its not working as i expect it. Their is a system variable called S:FS in logix that you can use as a bit...
5,118
Got into a bit of a debate the other day, and wanted to get some gurus' opinion/expertise on the subject. When duration of an output's ON (or...
10,766
Does anyone have some guidance on setting the Last Scan of Active Steps setting in the SFC Execution tab of Logix5000 controllers? I'm reading...
2,775
Hi,All I can't express my opinion well in English. You can't understanding, I am very worried about my write. I'm communtcation between AB EWEB...
6,705
