Probably.
Many Koyo PLCs have Modbus RTU protocols, either directly on the CPU or using a data communications module, and most SCADA systems support Modbus RTU. Depending on model there are lots of other protocol options - you need to look at the Koyo documentation and match it up with what you have available with your particular install of RSView 32.
