Total Fustration - PLC vs DCS
jaichains
Jul 2005
Rotherham
46
Guys,
I am in a total fustration condition and i am looking for feedback from everyone to help me out.
We have a PLC based DCS architecture on our oil platform i.e. PLC's are doing the job of DCS like F&G, PSD, ESD, PCS. I know that PLC do a good job in controlling a process but lacks the capability of a true DCS (advance process control like Statistical process control, Maintanance, production optimisation, alarm handling/rationalisation, industrial network security etc etc).
PLC's were never made to take over as DCS, i appreciate that with time they are getting better and better with some advanced control features but are never a good choice to control an entire plant. I need to convince my management to move out of PLC based system into a more robust and capable DCS (Delta V, Honeywell Experion or Yokogawa)
Please can confirm that the above statement that i have made is valid and share your views on this. Thanks in advance.
jaichains said:
....... but are never a good choice to control an entire plant.... I need to convince my management to move out of PLC based system.....
First, tell us why you believe a PLC system is "never a good choice to control an entire plant". I personally think that is an erroneous statement, but of course you really do need give us your definition of "Plant Control" .
What are you trying to accomplish to justify the cost of swapping your PLC components to DCS components?
Now, if you are talking "building" control systems HVAC/Lighting...you've got a point, but controlling a manufacturing process....
Elaborate please.
Good luck.
If you can't summarize why, & you're already sold on it, how in the world do you expect anyone else to come to the same conclusion?
To me, the big distinction was always that a DCS is centralized and server based.
But my direct contact with DCS is marginal. I know that the sales departments any of the vendors you mention would be more than happy to assist you in developing cogent arguments for a DCS. They're always on the prowl for a 'champion' within an organization.
Give 'em a call and ask to talk to sales.
Dan
DCS is like mainframe computers - Out of Date
The problem with DCS's is that they are big, expensive, centralised and quickly become outdated. Then you are pretty much locked in to something that gradually becomes hard to maintain, hard to keep people who really want to work on something newer, and as it is then obsolete you don't want to develop it further.
I favour using PLC's and then keeping them fairly small (task related). Use a SCADA system to tie it all together and you really have a DCS equivalent. Eventually you will find you need to change brand of PLC and SCADA you use. Resisting change for a while is good as you don't want to be suporting too many different things but when there is good reason then make the change.
Would these processes be..
F&G = Fire and Gas Detection System?
PSD = Process Shutdown System? (a guess)
ESD = Emergency Shutdown System?
PCS = Process Control System? (another guess)
If so would any of these processes require SIL ratings or ratings required by your industry or by your company?
I am not familiar with capabilities of a DCS but could you get SIL ratings (or whatever ratings required) with DCS software / hardware???
If anything this would be a first step towards building your case.
Never? Ever? I think you are getting sucked into the hype because the statement that I quoted above is male bovine fecal matter.
The line between DCS and PLC is blurred. The more you know about both systems the blurrier it gets. I know of numerous large plants that are controlled by PLC / WW systems. I can think of a few that are 200mmscfd plus turboexpander plants with full fractionation. The last one that I was involved in had a PLC on each engine, the turbo expander, and fired heaters as well as a "main" plc for process control and motor control all on an ethernet network with (6) Wonderware HMI's (not client server) all polling the 15 PLC's at once. No problems... not one. I built a C1/C2 controller for the DeC1 and it maintains bottom spec perfectly as long as the chromatograph does it's job. If the chromatograph fails or gets too far out of range the C1/C2 controller reverts to straight temperature control and alarms. I have routines built that calculate gas flow based on AGA8 and NX19. I have liquid flow routines that calculate the flow of liquid across an orifice that utilize flowing and 60 degree specific gravity. I built air fuel ratio control (curve fit) routines for some of the engines. I have a surge control routine for the expander that TTI approves of. I've done all of these things in PLC's and I've done them in DCS systems. I do not prefer one over the other. I make money no matter what the customer prefers. But... if I built my own gas plant I would install a PLC based system. It's more cost effective, more robust, and considerably more lean than a DCS system. By lean I mean FAST. IO update times at sub one second. DCS systems have SO MUCH OVERHEAD that you invariably find yourself slowing the scan rate on certain blocks down so that the system doesn't bog down.
The Delta V and Experian DCS systems are nice. However, they are essentially PLC IO with a very FAT top end (HMI). I love the way they program... I hate the way they work.
BTW-
F&G- should be it's own stand alone system. PLC works fine. DCS does not.
PSD- Either works here since so many things trip other things it's best to leave it in one system
ESD- I prefer hard wired ESD systems. Typically I'll drop the power on a PLC output card with an ESD relay as well as "tell" the PLC that the ESD system has tripped so that it can drop the output out as well. Kind of a twofer that you can't really take credit for in a SIL analysis (unles the PLC is safety rated which is gross overkill in a gas plant).
PCS- PLC or DCS... doesn't matter. Each has it's strong suite. Just don't kid yourself... if you "upgrade" to a DCS you WILL NOT save money. It is an EXPENSE. It doesn't create money... too many people sell DCS projects as a way to make money. Mooo...
One more thing- DCS = Distributed Control System. Have you ever pondered what that really means. Here's the deal... way back in the time just after electricity was invented, electronic control was making it's way into the market. Processing power was LESS than what your car has in it (by a long way) so they "distributed" the load over numerous control processors. So, if you uyse multiple PLC processors in a logical manner, networked together to a common HMI or HMI's then guess what... you have a distributed control system
Mike,
This is exactly what we have got on our plant. PLC's based DCS. I also understand that DCS is a generic term meaning just distributed control which we can get using PLC's also. PLC for F&G,ESD is fine. But DCS is much more capable control than PLC. see below:
ü
Production Scheduling/ Accounting
üExpert System/Statistical Process Control
üProcess modelling
üAlarm Handling/Rationalisation
üPredictive Maintenance
You want a complete "package" that has all these things. That is understandable and quite reasonable for a large proces application like an oil platform.
It is all software (except the "industrial network security" .. see below), so there should be nothing that impedes that a PLC based system has this functionality. Siemens PCS7 for example uses standard S7 technology to achieve DCS functionality.
The question is if there exists a "canned" DCS solution for the PLC platform that you have on your oil platform.
May we know what PLC it is ?
About "industrial network security", do you mean redundant networking, or access sequrity ?
If you mean redundant networking, then some PLCs supports this. Frankly I am shocked if you have an oil platform without redundant networking.
If you mean access sequrity, then there also exists solutions for this, and as far as the PLCs are concerned, it is transparant to them.
Jasper,
GE Fanuc 90-70 and 90-30 PLC's are being used on our platform.
Totally agree with you regarding PCS7 which is basically S7-400 PLC based DCS. Thats the reason i never mentioned them in my list above. But s7-400 are very capable PLC's,no doubt about that.
Yes, We have redundant networking. What i mean by industrial network security is access control, Intrusion detection. I agree that this feature is IT related.
This is something I have seen before. PLCs DO provide a stable, consistent form of control, with easy to access parts and materials. I work on oil platforms - I am assuming you are talking about production platforms? All of mine are fairly small, and have from one to five PLCs on them. I have seen (or heard) platforms that have Delta V or something similar on them. In my opinion, that's vast overkill for what can be gathered with a PLC and PC-based data gathering.
Why? The DCS is basically "top heavy" by design - all the controls are in one place, and all of the IO is distributed. This is good in some places, but on a platform you may need several PLCs that can either work seperately, or tegether, as needed. You don't want to take your platform offline for software changes, as this can cost money by loss of production.
"DCS" in the classic sense of a centralized controller isn't a good option for a high production facility. Don't give up on your PLCs!
I disagree, DCS is not centralized control. Like PLC it is distributed but is more capable and comes with a complete packages which is benefical for optimisation, production management for large oil platforms.
jaichains said:
Mike,
ü
üProcess modelling
All of the things that you list are doable in a PLC based system with the right PLC/HMI package without all of the overhead clutter and expense that a DCS brings to the table.
Structured Text language allows the programmer almost unlimited calculation power. The S7 allows the programmer to compile the code into reusable function blocks. Allen Bradley offers similar features with their Control Logix line. Unfortunately you can't compile the code into an FB but there are ways to call the routine interatively to do multiple calculations so that's not a hinderance. CLX has numrous function blocks built into the system with more coming all of the time.
Questions:
1) What DCS can do and PLC based system can't?
a) DCS have distributed I/O's but PLC's also have them
b) DCS can log various data, but PLC system with SCADA can also do this. That means all the points mentioned in post#9
Have never came across DCS so not in condition to elaborate much on this. But have desire to know what DCS can do which a PLC based system can't do.
I'm being tasked with supporting / upgrading these panels but no software, cable, documentation. I have an old laptop running XP and would like...
1,988
Hi everyone, I'm trying to perform a serial download with a Total Control Quickpanel jr (QPK-2xxxx) using an old computer running QuickDesigner...
1,662
Does anyone know where I might get a copy of development software for a TCP HMI?
2,275
Is there a way to count the number of tags (including dot fields) in RSLogix 5000 automatically? When I export the tag database and open it in...
2,995
Hey everyone, Recently installed a Siemens BW500 belt scale on a conveyor, and everything is nearly wrapped up except that we can't seem to get...
2,511
