Micrologix 1200 sticking relay
locotumbler
Jan 2013
Otsego, MN
98
I have an issue on a system i've inherited. I had one of my relay outputs sticking on. When the lights off and i'm still getting voltage through it and I tap on the unit itself it releases. I thought initially since the system was around 9 years and over 5 million cycles that it simply failed. I replaced the PLC and had no issues for about 50k cycles, with the way we are running it now is like 3 days, and the relay started doing the same thing. It is running a small solenoid valve. I moved the output to a different unused output but on the same COM supply and had the output itself run an ice cube relay. I was gone yesterday and come in today to find out it started doing the same thing.
the system is running 24vdc through the relay. Any ideas on where I might start a deeper inspection into this? Could it possibly be getting back-fed from somewhere else on that COM?
Thank you in advance.
If it is actually relay output, it's probably due to voltage spike from connected coil. Put in a flyback diode across the solenoid to extinguish voltage spikes.
relay outputs have a lifespan before they fail, look at the specs of your system.
I had the same issue, and eventually had to go to a triac output.
in your case I would go with solid state dc outputs and also do as suggested.
james
Hi everyone, I'm working on a project where I need to exchange data between a Siemens S7-1200 PLC and an Allen-Bradley MicroLogix 1400 PLC. The...
485
I have a MicroLogix 1200 that has an 8 input and a 16 output. Every 6 months-year I get a fault and when online go to error it is something like...
448
Have a bad output on a Micrologix 1200. Moved wire over to an available output, changed program to associate with new output. downloaded program...
727
I need help achieving the following task: ML1200 sending 4 to 20 mA thru analog output ch0 to a DC speed controller analog input(4 to 20 mA) my...
649
Hi there I am new with this thing and i don't know how to connect Allen Bradley Micrologix 1200 PLC to Raspberry Pi using USB to RS485 in NodeRED...
2,231
