Panelview plus screen calibration
clank
Jan 2005
Ontario
46
Hi Guys
I need to calibrate a screen (2711P-T6M38) but I do not have software. Can I get to configuration from boot up and how?
on most pv+ you can access the config by power cycling the panel and either hitting the white box on the bottom left during bootup(or hitting F1 at that same time).
When booting up, i touch bottom left corner. It goes to page that reads Firmware may be corrupt press F1 to download press F2 to continue. When I press F2 it completes loading application. How do I get to configuation page if I can.
Hmm, Firmware may be corrupt eh?
I'd probably push a clean copy of the firmware back to the Panel and reload the application, but you say you don't have the software...
OK I got there...once I got to task manager,I ended task and it took me to configuration page
Thanks again
I have 2 PV Plus 7 screens used in the same system that both have touch screens that can be challenging to activate after they haven't been...
563
Every time I power this unit up it loses its IP address and goes to DHCP . When I goto the config the IP address is 0.0.0.0
728
Any good idea how to dim the display on a panelview plus performance serie b, at idel. Screen saver is not supported yet I have don it in global...
2,199
New PanelView Plus 7 Performance Series B P2711p-t10c22d9p out of the box I went through the touch calibration screen and then to the "Welcome to...
4,820
I am having an issue where the alarm history on the HMI is zoomed way in. It is as if even though my font size is set to 6pt in factory talk ME...
2,767
