Ben
bmoritz
May 2019
Enid
Hi, I am working with a Red Lion CR3000 and I am able to extract the file that is currently downloaded to the HMI, but when I name it and save it and then when I log back in, it does not extract as the file name that was just saved, it makes you go through the same process
I saved the file that I extracted from the HMI, then closed Crimson 3.1, then opened it back up. It is extracting like it should, I was on line with tech support at Red Lion, thanks for replying though
That sounds normal to me.
I have some old RSLogix stuff . . . I downloaded the programs and stored them away.
Next time I want to access the PLC first thing I have to do is download the program
again.
I would think that the PLC (or in your case the HMI) has no idea whether you have
an archive copy of the program or not . . .
Poet.
Have a job coming up where I'm using a bunch of Turck TBEN-L4-16DXP modules. They say they're configurable as inputs or outputs. I've downloaded...
1,810
Hey all, does anyone of you have some experience with combination of BL67 gateways and TBEN L1 IO modules (using Modbus tcp)? It looks to me like...
880
Hi all, Hoping someone out there has used these units and can give some honest feedback, are they great or rubbish? From what i can tell, they...
1,249
Hey all, I'm trying to set 4 of the last I/O to be outputs. The manual says to push the set button (which I assume is the one next to the rotary...
3,285
Hi thanks for your information. I have a problem, I forgot my pharao plc password. please help me for unlock it.
2,645
