ACS800, Speed Limits
Without also changing the Motor Rated Voltage, wouldn't you be sending too low of a voltage to the motor at reduced speed/frequency? Maybe an autotune takes care of that...
I read manual about Auto Tune and I was not able to perform that function.
May you please explain a little bit how it works?
Regards
First, I am not that familiar with this model. But, on the many different models and manufacturers I have seen, the Motor Map (Nameplate data) is just a starting point for the Autotune function to tune the drive to the motor.
The Autotune finds the resistance, inductance, magnetizing current, etc. on the motor and uses this data to calculate the required current (and thus voltage) the motor requires for a given torque and speed. The range of the test may not allow the tune to successfully find the optimum settings if the initial data is not 'close enough'.
Hi, I have issue with acs800 starting the motor in reverse for like 5-6 seconds with a max speed of around -220 rpm before it goes to the...
1,932
Members of this forum helped me out a great deal a couple of years ago with a question I had regarding acceleration during torque control of...
4,305
Good Morning everyone, on board our ship We have a acs800 drive a AC motor. In the display of SUPPLY SECTION of acs800 appear alarm 4280 (the fan...
2,185
I am getting an AD1_PLACE1 fault on my drive and am stumped, any pointers would be appreciated!
1,843
hi everyone,i want to ask about changing the value of motor running time in ABB VFD acs800, because i reset this value by mistake
1,842
