How to Interface a Denso six-axes arm VP6242G with a AB MicroLogix 1400 PLC
drey
Apr 2011
CA
Hey, I'm new to this forum and I'm hoping any of you could help me with my problem..I'm currently trying to interface a Denso VP6242G six-axes arm robot with a AB MicroLogix 1400 PLC but I've been getting an error message on my teach pendant every time I run my PLC code. The goal is to have the PLC send command area bits and data area bits to the robot controller as inputs that would cause the robot controller to do Operation Preparation (motor ON, CAL, SP 100, external mode switching), execute the program number per instruction, reset the program, return to home position and switch the motor off when finished. I realize that the PLC code will depend on the layout of the system, but if any of you could provide any suggestion..I'd really appreciate it. Thanks!!
via EtherNet/IP..I also connected the necessary wires of the Mini I/O for the step-stop (All tasks), strobe signal, data area bits (0-2), and command area bits (0-2) to the PLC.
The 1400 has some CIP messaging. I don't think the 1400 will do your EIP control you want. You may want to ask Densco if they can talk PCCC.
There are several Ethernet bridges that can handle this for you.
Check the specs.on what the robot talks and what that PLC can talk.
JeffKiper, you right..I just realized that I connected the PLC to the computer via Ethernet but the robot controller is connected to the PLC through Mini I/O...
Mini I/O is a user/system I/O connector..basically, it allows the user to interface the robot controller with PLC, sensors, switches, or external devices..
Hey guys, I just wanted to see if any of the bright minds on here had any opinions on these relay interface modules. Particularly, I would love to...
78
Hello world! The company I started working for has these valves that they ordered years ago as spares. now we have to add couple valves on...
223
Good morning fellow sea captains and wizards, I am being asked to do the above and obtain 4 values from each slave, I know about the MRX and MWX...
32
992
Does anyone know why the connection interface is greyed out and says why I can only use Teleservice instead of the other options like PN/IE? I am...
266
I am attempting to generate a VBA script within FactoryTalk View SE to open a Google Chrome webpage (PI Vision) when an object is right-clicked...
146
