Reading encoder for input/output and limit reading
yard1e
Sep 2019
Porto
Hi, I'm just a complete newbie on ladder logic and plc programming and I started a few weeks working with that, also it's my first post here, I'm working with an omron plc and I have an encoder attached to a rack and a pinion that reads the move of a component that is moved on a rail with a motor.
The encoder sends a signal ranging from 0 to 10v and I already set the limits physically on the encoder, but I need to measure that component distance outside of the range from a reference point in millimeters. First I need to convert the position in millimeters (I saw scl and apr functions but I don't get how I proper use it) so in an HMI it shows the proper distance that this component is placed at a reference point, set limits so this component so it only rides forward and backwards on that range and let the user input a value in millimeters so it travels to the desired position.
I tried to convert the signal in milimeters with a couple of mathematical operations but I think scl or apr is more suited for that operation, I have the conversion working but I think it can be optimized.
Another thing is that I need to store the current value because it oscillates and I'm using a compare function <> to check if the value has been changed to call the move function, probably here's another good way of doing it with switches.. I dunno.
The last thing is I need to reposition the component because when it reaches the value it travels a lil bit further so I need to make it go inside an approximated value (-1mm or +1mm).
Is anyone here that have done something similar and could help me out? It's my first post here and I'm already asking for too much... I did a research over the internet and here but could not find anything similar for my problem...
Hello all. I have an issue I have not been able to find an answer to online. I have a 1794-VHSC connected to a Contrologix PLC and a Sick...
2,423
Hi, Everyone I am interfacing rotary encoder(incremental encoder) with PLC. This encoder using for speed measurement (RPM). The encoder is giving...
4,551
Hi all, Anyone can tutor me that how to write the formula for encoder to read the motor RPM(Omron PLC). Thanks in advance
2,730
Hey guys I have a TWK encoder . WIth 4096 ppr and 334 mm /turn. I would like to get position from it.. How to count the pulses . I have...
2,814
249
