Arp traffic over Ethernet radio
TheWaterboy
May 2006
-27.9679796,153.419016
1,924
Arp traffic is important to switches in a dynamic environment, and not a problem for a high speed network, I understand that.
However when I am using Ethernet over radio and hoping for 19,200 speeds, ARP traffic is clogging the system by taking over a cycle at the expense of other traffic.
It's a polling network and I would like to control when radio comm takes place. This is a completely static IP network like many are, so ARP is not needed to locate changes very often yet the EN2TR and the EN2T modules are pretty chatty so far.
Is there any means to quiet them down?
If the ARP traffic was generated by a linux box, then probably yes
What is the period? Seconds or minutes? PLCs seem to be big on quick discovery, so I suspect the former. If there is nothing in the communication configuration menus, then I suspect firmware is the only solution to quieten the source, probably a non-starter.
What about filtering at the Ethernet "transducer?"
Transducer ?
LOL, that's why I put it in quotes, it's an analogy to a physical measurement that becomes 0-10V or 4-20ma via a transducer.
What I meant was the conversion from Ethernet level 1 and 2 to whatever the "radio" is.
I don't know what the proper term is. Converter?
It's an Ethernet radio . . . there is no conversion.
Umm, if you start with cat 5 at 10/100MHz on the PLC, and end up with 19.2kHz over the air, there's gonna be a "transducer." It may be only the physical layer, layer 1, but there is a physical change in the character of the signal.
My point was whatever device makes the conversion might be aware of a layer or two above it and be able to filter out the ARPs. Basically saying the same think OkiePC did.
If the radio doohickey won't oblige, then I think one of the few options would be a purpose-built microcontroller (RaspberryPi?) that acts as a passthrough with a filter that ignores 99.XXX% of the ARP packets coming from the cat 5 side. They are broadcast packets, IIRC, and no one will miss them, as you note.
did you ask The Google summat like this => "ethernet radio" "filter" "arp"
GE MDS Orbit. Brand new.
If this extraneous TCP traffic can't be controlled it really negates the viability of ethernet over radio at low bandwidth. I need the low freq rf here because of topology and that comes with low bandwidth. Really no other option but cellular and thats $$$.
BTW the radios also do serial and that works fantastic (until I put a single Ethernet connection it), but for RTU, serial PLCs that can talk DF1 are becoming a rarity.
Thankfully the 5380 has a serial module that works now so I might have to use only serial, which limits what processors I can use for the polling master. On and On...
I hear you. When the Micrologix 1400 goes bye bye, I am pretty sure we will be switching to Do-More. I must have Modbus RTU support for some legacy gear we support, and I must have RS-232 ports because our two favorite radio systems require it.
I recently gave away a stack of Cal Amp Viper SC modems because there are too many headaches trying to make an Ethernet radio network reliable with them.
I have installed a network of Xeta-4EL that were much better than the Cal Amps, but quite expensive and trying to use that extra Ethernet capability for something like RSLogix over the air...well...it's actually faster to drive 15 miles to plug in than wait on the packets to get sliced and diced and reassembled...They're reliable though except for lightning. If I had that job to do over, I would use serial modems there too. One simple config for all stations, and 1/3 the price.
I hear you. When the Micrologix 1400 goes bye bye, I am pretty sure we will be switching to Do-More. I must have Modbus RTU support for some legacy gear we use and must have RS232 ports because our two favorite radio systems require it.
Look at the 5069-L306ER and the 5069-Serial module. It seems AB listened and made DF1 work with only a firmware update. I haven't tested it yet but they make the claim and showed screenshots. I'm pretty sure Modbus RTU was already in there.
I have a couple sets on my desk and a feeling I'll be testing that myself sooner than I expected.
seems like the prosoft 900mhz radios were able to handle this. outside of that maybe putting a managed swich or router in between the plc network and the radio would work.
Can you quantify "chatty" ?
Do you have a tap/mirror at the master side of this system that you are using the monitor the traffic ?
I just hooked up a tap and Wireshark, and monitored my 1756-ENBT using the filter:
(arp) && (eth.src == 00:00:bc:33:a8:09)
Mine sends out an ARP probe every 122.45 seconds.
Of course ARPs are broadcast packets and every device on the network sends them out periodically. If you've got a router on the network that's providing DHCP addresses to anything, it's probably the most common source of ARP packets.
Sometimes you can adjust the ARP cache timeout, this is usually done on a switch or device that holds an ARP table. I’ve never known an AB device outside of their switches that allow this adjustment.
I’d love to see a WireShark log of what your are experiencing. I have know AB devices to not handle well erroneous ARP request caused by other devices.
Also network storms are pretty much looping and multiplying ARP requests, I know it would probably cause more havoc than you are describing, but I’ve never seen how this would react with a throughput restriction of a radio in between.
We have one PanelView that is generating about 67% of all packets on it's subnet. Approximately 49 ARP requests per second. I believe it may be a...
3,355
Hey everyone, Recently landed a job in an environment where I have pretty good access to both the hardware and software surrounding all of the...
1,528
Hi! Does anyone have software JW-100SP for PLC SHARP ZW-501CU?What type of cable do we need?
1,145
Looks like we may be acquiring a couple of presses with these control systems. I saw pictures of them and was less than enthused 🙃 Just...
1,402
Wanted to know if any one uploaded or download a program to a SS2000Ci Drive. I keep getting message" The contoller did not respond". How do I fix...
1,230
