SLC 5/04 Processors Randomly 'Disconnecting' from the DH+ network.
Simon Webber
May 2007
Cape Town
Our plant has a DH+ network containing Allen Bradley SLC5/04 & Allen Bradley PLC 5 processors.
The intermittent problem we are having is that one of our SLC 5/04 processors will 'island' themselves from the DH+ network therefore not communicating with the rest of the plant.
To get it back onto the DH+ network we have to switch the processor from 'Stop' mode back into 'Run' mode.
The problem is not confined to one particular SLC 5/04 processor, it happens randomly with any one, somtimes two SLC 5/04 processor throughout the network at least once a week. Note that there are no problems with the PLC 5 processors.
While the SLC 5/04 processor is 'islanded', when I autobrowse the DH+ network using RS Linx,the fault code next to the 'islanded' SLC 5/04 processor shows: COMMS. ERROR 00000001. Has anyone any ideas why they are randomly throwing themselves off the network?
The only time I have had 5/04 drop off the network like you are describing is when I did not have a terminating resistor at both ends. It would just randomly drop off the processors.
I'm sure others will chime in on some of the other problems you need to check for.
Hello All, I’m trying to connect some SLC 5/03 and SLC 5/04 processors to RXLinx but am unable to see the connection to the processor in the...
2,294
Is this possible to do on the SLC platform? The reason I ask is I would like to upgrade from a 5/04 to a 5/05 in one machine to get the use of...
1,724
I have SLC 503 CPU which i am not able to access because of a password (there is no way to get this password) and it is having a fault, I have...
1,626
Hello everybody, have question: my customer wants to have hot backups of his 5x SLC 5/05, Can I install them in one rack and keep in prog mode...
2,494
Is possible to have two processors SLC 5/03 and SLC 5/04 on the same rack?
3,494
