s7-1200 plc and encoder
tulip
Oct 2005
ist
236
Hi everybody.An encoder connected to S7-1200.When motor is turned encoder is producing pulse ,but pulse counting is progress than plc has error.Error led is blinking when encoder is producing pulse..and following message is shown.
Diagnostic buffer:
Temporary CPU error.
Buffer overflow for OB 0 events-Function will continue (system reaction)
Thanks in advance..
Hi Folks. Has anyone used an SEW EI7C encoder with an S71200 PLC? If yes, how is it done? I use this same encoder in EI76 mode with a...
260
can give EXTERNAL ABSOLUTE ROTARY ENCODER signal to S7 1200 Plc without SMC(sensor module cabinet)....why? AND...
5,574
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
81
Hi. I’m trying to upload program from existing PLC S7-1200. Create new project in TIA v15.1 then upload. After upload successfully, go online but...
219
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
2,859
