Gx works2
TECHUSER
Feb 2021
melborn
36
Hello friends,
i am using gx works2 in Mitsubishi q series Plc.i have 3 plcs in panel which devides in program in 3 parts
i want to know how i can i stop the motor whose programming done in 1st plc.
but due to some programming reasons i want to stop it from 2nd please,
please tell me how to take the reference.
suppose y2 is my motor(present in 1st plc)
want to off with x5 (present in second plc)
How to take reference from other plc??????????????????????:eek:
please help as soon as possible...............
Posting the same question in four threads won't get a response any faster. All it will do is cause confusion as different people post their answers in different threads.
Program the X5 signal to control a discrete output in PLC#2. Wire that output to an input in PLC#1 and include that input in PLC#1's control of the motor.
thanks for your valuable reply.....
is it possible without hardware changes..........like any mutaul memory bit or somthing else.....................
thanks
What sort of links have you between the PLC's is it NETH, Ethernet or are you using digital I/O, need more information.
all plcs are communication through ethernet..........
and now i want to use memory bit of 1 plc in plc 2
that it
how can i make the memory bit like m345 global
that it
I am not so in-depth on Mitsubishi technology. But I think the only way you can achieve this is by means of instructions supported by the MELSEC programming language to read and write bits in the M area of remote Melsec PLC. There is a specification Melsec TCP protocol that all PLCs with an Ethernet module in the case of older Melsec Q PLCs, or in the actual PLC in the case of Q03UVD processors, support.
The Melsec TCP specification allows reading and writing of elements in remote PCLs, but you do have to configure properly all the Ethernet parameters in all processors and then write the correct program.
I have a FX3U clone that I am failing to get a simple Structured Text example working on and would really appreciate some help. I created a...
30
941
I'm starting learning ladder programming. I bought the FX3U kit + coolmay HMI from aliexpress. I'm doing basic testing and uploading codes. I...
57
3,826
Hello to all, is my first post on the forum, I searched everywhere, but I could not find an answer to this problem; I am quite experienced in...
958
hello, I'm trying to set up communications between two Mitsubishi L series PLCs using the built in Ethernet port. All of the information I can...
1,843
Hello Friends, I am trying to index M Bits, however GX Works2 is not allowing it with following message. https://ibb.co/zPcqj6M...
1,372
