[New Thread] Analog module in 1771-ACN15 and ControlLogix
Ken Roach
Apr 2002
Seattle, WA
17,482
Recently posted by BarbaMan:
I am trying to transfer analog data from a 1771-ACN15 remote chassis to a 1756-L62 ControlLogix processor. The BTR in my ladder program seems to be working, but I do not get any analog data. Only the diagnostic word from the module is received. What am I doing wrong and how can it be fixed ?
More information is needed to provide an answer to this problem.
1. What is the part number of the analog module ?
2. Do you also have a BTW instruction programmed to provide configuration data to the module ?
3. What is the pre-condition logic in the rungs containing the BTR and BTW message instructions ?
4. What are the values in the configuration data block for the module ?
5. Is the BTR module completing with a too-short data block, or is there simply zeros in the data where you expect analog data ?
Screenshots or the *.RSP file are the best way to communicate most of this information.
My best guess is that you don't have a properly configured BTW instruction to set up the module (channel scaling and enabling) so the module is returning zeroes for data.
I'm going to start a project for work that will be time consuming over the next year or so. It happens to be a rental unit, so I'm not...
1,288
Hi all, I have an issue and I don't know how to proceed with it. So my problem is... I have several UDP connections. And all communication with...
20
4,298
In addition to our help with automation controls and troubleshooting, I suspect a lot of us have access to 3D printers. We can use these to help...
1,210
For a decade I've been around this forum, the new, first-time threads (in a log-in session) were display in bold typeface. The subject line...
22
7,846
Hey Folks. I had a thread a while back where we talked about the versioning issues that can arise with Studio5K. It has been determined that I...
2,407
