SquareD SY/MAX Program Export/Printing
PLCXPRT
Jan 2018
Wisconsin
Would anyone here be a resource to print a SY/MAX 400 program in a legible format for me?
I have the .RNG and .LBL files for the application, but do not have the programming software, and have little interest in buying it since this is the only instance it would ever be used.
Many thanks in advance, and there's a beer/coffee in store for your help!
Put all the files in a separate folder and then zip the folder. Attach the zipped file to a post here using the Go Advanced button at the bottom of the screen. Someone who has the software might see the post and print it to a .pdf for you.
here is a printout of the rungs, could not get the lbl file to load, the symax programmer I have uses .rng, .reg, .hdr and .lab files
I'm guessing here but I think the .lab and the .lbl are similar so maybe you can change the .lbl extension to .lab and get it to work that way. Your software might have an import feature also. If nothing else, sometime around April 1 I will be back home where I have the software. Maybe then I can add the labels to the printout for the OP.
Printout
Sorry I took so long getting the files printed with labels plus the label only file. I just now today was able to get to the computer with the proper software.
@GeoffC,
To get it to print correctly, I had to change the file format to SFW type and use a DOS2USB utility to re-direct the LPT1 port.
I am working on a conversion from a SquareD PLC to a SLC series PLC. I have run across one issue that I can not seem to overcome. The older system...
1,676
Hi I was wondering if SquareD PLCs scan from left to right like ControlLogix or in a column like fashion like Modicons.
2,431
Hey all. I do hope someone can give me a quick answer. I haven't used this software in a couple of years, but need to look at some possible...
2,173
Hello All. I am going through an O & M manual, and I chance upon a power meter product by SqaureD, PM710. I searched through SquareD website, and...
4,253
I have the PLC Code for a Symax 300 but I don't have the software. The software cost is $3800. We are upgrading the 300 to an AB controller but we...
1,608
