Cisco Catalyst 2955 Password recovery
Densam
Apr 2005
113
Please help i am struggling to break the the key on an Dell Latitude E6430 windows 7:sleep: I GET UP TO[/U][/U] flashfs[0]: 316 files, 5 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 4938752
flashfs[0]: Bytes available: 2802688
flashfs[0]: flashfs fsck took 6 seconds.
...done initializing flash.
Boot Sector Filesystem (bs:) installed, fsid: 3
Parameter Block Filesystem (pb:) installed, fsid: 4
*** The system will autoboot in 15 seconds ***
Send break character to prevent autobooting
HERE I PRESSED ALL THE COMBINATIONS AND FAILED. I used Hyper-terminal and Putty still not capable.
I am supposed to interrupt(stop auto booting of the switch) the ios loading into the switch. This will enabled me to reset the switch to factory setting. Then i can navigate around the software. i have read the manual but this stops at windows 95 i could not find anything about windows 7
If I recall correctly, using putty you will right click, select special commands and the break command should be there.
Hi Sir/Ma'am, i'm having a trouble in communication of L18ER-BB1B when connected into a CCE500 switch. Please see attached images of the existing...
4,984
Hi, I'm setting up comms at a station and I'm working with Cisco IE 3400H switches. I have been able to configure them following the Harware...
554
Hi All I am using Oracle VM Virtualbox on a windows 10 I have my license on my host and link my vm's using a host only connection, everything is...
555
When I log on to my Cisco switch via a browser, following the express setup instructions (after boot up is complete, hold exp. setup, exp light...
1,918
Hello, I have Cisco network switches that I am wanting to monitor in a control logix processor (Cisco WS-C2960X-48FPS-L). I want to monitor...
18
3,292
