Msg function micrologix
02js4130
Jun 2014
Wales
38
i have both a ML1400 and a ML1500 and i would like to make a network using DH485. The ML1500 Will be the main plc with the program and i would like to use the ML1400 to just store the recipie data that the 1500 will need. This has come about due to full memory on the 1500 hence now i have 2.
I understand that the MSG function need to be used but i am not sure how it is used, can anyone help me please?
Any chance you can just add a memory module to the 1500 ? 1764-MM3 has 16k and then you can save the 1400 for another project
I have always thought that Ethernet/IP Implicit messaging was the high speed data that is just "magically" there once you set it up, and if you...
4,545
Hello, Sorry for my bad English The message function is a little new for me on the RSlogix 5000 platform, especially the CIP function...
3,647
i try to move with one msg function array that i created in rslogix 5000 data type that have 1 int and one real but i have an error messege why?
2,073
Good afternoon. We upgraded to SLC 5/05 processors a few years back but I don't think our MSG function has been working properly. The data...
1,710
Need help trying to resolve a problem with using the SQLErrorMsg function. I use SQLSelect to query a MSAccess list to search for a product code...
2,537
