S5 Functinoblock Question
JIMCON
Sep 2005
SWEDEN
124
Hello..
Right now im gonna convert my S5 Functionblocks to S7..
But I cant translate 2 words in the S5 FB declaration area.
IB = input byte
B = byte
IW = Input word
but hmm ?? IWI = ??
IBI = ??
I dont get this at all. ?
M001: ?? what does it stand for
DECL: DBLS B
DECL: DBG1 B
DECL: G1KW IW
DECL: G1LS IBI
DECL: DBG2 B
DECL: G2KW IW
DECL: G2LS IBI
DECL: DBG3 B
DECL: G3KW IW
DECL: G3LS IBI
DECL: DBG4 B
DECL: G4KW IW
DECL: G4LS IBI
AN =G1LS
JC =M001
DO =DBG1
L =G1KW
DO =DBLS
T DW 1
T DW 11
L KF +1
T DW 16
JU =M002
M001: DO =DBG1
L =G1KW
DO =DBLS
T DW 1
L KF +0
T DW 11
T DW 16
M002: AN =G2LS
JC =M003
DO =DBG2
L =G2KW
DO =DBLS
T DW 2
T DW 12
L KF +1
T DW 17
JU =M004
M003: DO =DBG2
L =G2KW
DO =DBLS
T DW 2
L KF +0
T DW 12
T DW 17
M004: AN =G3LS
JC =M005
DO =DBG3
L =G3KW
DO =DBLS
T DW 3
T DW 13
L KF +1
T DW 18
JU =M006
M005: DO =DBG3
L =G3KW
DO =DBLS
T DW 3
L KF +0
T DW 13
T DW 18
M006: AN =G4LS
JC =M007
DO =DBG4
L =G4KW
DO =DBLS
T DW 4
T DW 14
L KF +1
T DW 19
JU =M008
M007: DO =DBG4
L =G4KW
DO =DBLS
T DW 4
L KF +0
T DW 14
T DW 19
M008: DO =DBLS
L DW 11
L DW 12
+F
T DW 21
L DW 13
L DW 14
+F
T DW 22
L DW 21
L DW 22
+F
T DW 23
L DW 16
L DW 17
+F
T DW 24
L DW 18
L DW 19
+F
T DW 25
L DW 24
L DW 25
+F
T DW 26
A(
L DW 26
L KF +0
>F
JC =M009
L KF +1
T DW 26
M009: JU FB 243
Z1 : DW 23
Z2 : DW 26
OV : F 0.3
FEH : F 0.3
Z3=0: F 0.3
Z4=0: F 0.3
Z3 : DW 27
Z4 : DW 30
BE
JIMCON
If you're declaring inputs and outputs for your function block you also have to declare the size: BI for bit, BY for byte, W for word and, if using a 135 or higher D for double. So, IBI in fact is I BI or Input Byte and IW is I W or Input Word.
M001 is a label. You can let the program execution jump to a label with the instructions JC <label> (conditional) or JU <label> (unconditional).
The jump to FB243 can be translated to S7 by a simple integer division ( /I ), so you don't have to translate FB243 at all. That would even be impossible, because that's a propietary routine from Siemens embedded in the operating system ROM of the S5 PLC.
Kind regards,
Thanx alot jvdcande.
I guess i have to spend the rest of the week understand how these FB´s works in S5 contra S7..
Aaah Headache o_O I dont like S5 at all lol ... :cry:
If u got some good links to pages with some help pdf´s just post it up :geek:
Are you using the S5->S7 translator provided in Simatic Manager ? This will give you the S7 equivalent of S5 where possible. Any areas that will not translate will be highlighted and will give you a further list of queries.
It only work on basic instructions. It dont work on the code above.
Speaking about the S5 code above. I now atleast know that "DO" means Indirect adressing.
This is waht i have understod of the code above.. But cant find the way to translate t to S7..
..........AN =G1LS <-- If not G1LS
..........JC =M001 <-- Jump M001
..........DO =DBG1 <-- Point at DBG1
..........L =G1KW <-- Load G1KW
..........DO =DBLS <-- Point at DBLS
..........T DW 1 <-- Transfer contents of ACCU1 to DW 1
..........T DW 11 <-- Transfer contents of ACCU1 to DW 11
..........L KF +1 <-- Load konstant +1 into ACCU1
..........T DW 16 <-- Transfer contenst of ACCU1 to DW16
..........JU =M002 <-- Jump to M002
....M001: DO =DBG1 <-- Point at DBG1
..........L =G1KW <-- Load G1KW to ACCU1
..........L KF +0 <-- Load constant +0 into ACCU1
..........T DW 16 <-- Transfer contents of ACCU1 to DW 16
DO =DBG1 means process the block passed as a formal operand. In this example, DBG1 is a data block. To do the same in Step7, declare a parameter of type BLOCK_DB (e.g. DBG1) and then use OPN #DBG1
Ok shall I declare it in TEMP as a Word then..?
U mean like this ?
AN #G1LS
JC M001
OPN DB [#DBG1]
L #G1KW
OPN DB [#DBLS]
T DBW 1
T DBW 11
L 1
T DBW 16
JU M002
I put the following code through the S5 to S7 converter:
Code:
Decl :DBLS I/Q/D/B/T/C:B
	 :DO =DBLS
	 :L DW  1
	 :BE
and here is what it produced with no errors:
Code:
FUNCTION FC 67 : VOID
  VAR_INPUT
	DBLS	  :block_db;  // DBLS
  END_VAR
  BEGIN
  NETWORK
	   OPN #DBLS ;
	   L   DBW 2;
END_FUNCTION
I strongly recommend you use the convertor and then resolve each conversion issue as reported.
So it is possible to paste specific code into the S5 file converter. ??
I thought you only could convert whoe projects ?
Ahh uhhmm forget what i said... now i know how u did..
When you call the block, the parameter you will enter will be a data block, DB25 for example.
Ok do I have to create this DB ? Or is it created..
Anyway I took your advice and used the konverted file.. And it worked as u said :) Thank u so much for that help. But now im facing another problem.
I now have the FB56 ready and inserted in my FC55, and i have tied all variables to it except the one´s that are word "input and "output pins. The case is that in the blocks in S5 they have just entered (ex. DW 153) on an input pin. But when i want to do the same in S7 (ex. DBW 153) on an input pin, it doesnt accept this.??
Maybe i have to create a DB and declare all the DBW´s ?? (ex. DB150.DBW153) or shall i use MW ?? is it the same ?
Hmm but then i have to open that DB every time i want to write to a DBW ..
S5?
Yeah, it works... eventually, but only after a great deal of mental mind-f'ing... or rather, mind-bending.
But I've always had to wonder... what the hell were they smokin' when they came up with that particularly obtuse way of looking at logic, logical elements, and logical functions?
If you are switching to an S7-2XX then you will be mightly impressed with the difference. Once you shake the S5-think, you will find that you can think more rationally, and more easily... without all of the mind-.... bending.
However, if you are switching to an S7-3XX or -4XX... well, you won't be moving far from where you were. In that case... too bad for you.
It's a damned shame that Siemens is trying to down-play and, probably, eliminate the S7-2XX line. They stumbled onto the best development philosophy when they bought the TI line... and now they are running it into the ground... to ultimate elimination.
Are all Europeans this crazy? Or is it only the Germans?
My main process was designed and built by a German concern. After we ran it for a while according to their "think"... we had at it, in a practical sense. Control-wise, and maintenance-wise, they wouldn't recognize it now.
So... is it all Europeans, or is it just the Germans?
I recently uploaded an aplication from a Panel View, created a new screen and now that I've downloaded it to the Panel View, all the texts have...
170
I have never had the pleasure of working with a "Thermistor" until now and have a question. The Thermistor is a 10KOhm 4-20mA 2-wire device and I...
152
Hi All, So I have a main routine with an instruction that's executed by XIC "Run" I have a JSR located on a rung below it. In the logic for that...
247
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
111
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
203
