Crimson 3.0 image display without tag
laserweld
Oct 2014
Cleveland, OH
23
I have a very simple question. I am wondering if it is possible to have a img primitive display an image with no tag associated with it. I have a screen I am using as a popup. I have the yes button attached to a tag and the no button is just used to close the pop-up. I am wondering if it is possible when the no button is pushed for it to display the 2nd image like the button with the tag does. See attached for example of what I am referring to. Thanks
View attachment test.zip
If you're just wanting the visual feedback of the button appearing to be pushed, use an internal tag. Since the button already has an action assigned to close the pop-up, one way to get both actions would be to change that to User defined, make the On Pressed action set the dummy flag to a one, and make the On Released action set the dummy flag to a zero and hide the pop-up.
See attached test file
Use IsPressed to select the images.
Image 0 will be shown normally
Image 1 will be shown when IsPressed = 1
You only need to type IsPressed
Even better. I hadn't thought about using button properties for a button without a tag assigned, but it does appear to work.
Hi everyone, I am using Crimson 3.0 to edit a project file created by a vendor. I have created a widget, and spent some time figuring out that...
1,848
Page 171 of the Crimson 2.0 manual for RedLion G3 HMI series talks about being able to display a photo/image as a primitive object. On the HMI G3...
24
5,838
I am trying to use the Animated Image to use 4 different images using 4 different tags. I know i can just layer them and display them when active...
3,839
I've got a few images I want to play together in series to make an animation. I've got the frames already setup as in a single image object, but...
2,988
Please help me understand how to manage images in Crimson. If I use 'include data = yes' the manual sounds like it will embed the graphic in the...
1,406
