Ab kinetix 300 i/o expansion block required USER MANUAL INCORRECT??
Skolnik
Aug 2015
Chicago
Hi folks, I've been having a problem enabling my Kinetix 300 over E/IP. 1stime Kinetix/EIP user here. A few questions Im hoping to find aswers too.. Any help is appreciated
Project Components:
Servo Drive ------- Kinetix300 E/IP
PLC ---------------- Micro850
Software ----------- Connected Components Workbench
I've connected to the drive over E/IP; have modified parameters in motionview, checkphasing runs fine; Digital IO>enable... (all from the manual)
...and the drive will not enable. Shunt in not wired; is this required?
So I found one thread and one written document stating that the i/o expansion block IS required in order to use EIP communication?
Link 1 http://cednebtrc.com/ftp_bbernier/K300 Minimum Wiring needs.pdf
Link 2
http://www.plctalk.net/qanda/showthread.php?t=87477
Any Advice on how create the worlds simplest program in CCW in order to write messages in to the Drive using EIP.
Thanks!
Have a system that has been running for over a year and all of a sudden getting a ExcessiveVelocityFault on one of the drives when the MSO command...
138
Hello PLCS.Net Forum, First time posting. Let's assume I am a novice. BASIC PROBLEM: My servo/linear piston is no longer zeroed to the...
203
Hello. I have a few machines that use Kinetix 300 (each machine has two drives). Both drives on one of the machine keep losing IP address. They...
92
Hello, We have had a machine running for the last 10 years. It has 2 x Kinetix 300 drives. Around a year ago, one of the drives failed. We were...
420
Hello, I have a die punch machine with servo motor for material feeding. I'm using Kinetix 5300 to control the feeding system. Every recipe have...
511
