OT: VERY COOL!! Philae
I was pretty impressed. As you say, to be able to shut down a machine for ten years, and then fire it up and have it pick up and work perfectly is something most of us can only dream of ;)
I noticed in Rockwell AOIs, they add a BOOL Output parameter at the end of the "Parameters" list of each AOI that carries the same name as the...
71
Is there a way to use the FAL instruction to do +=2 instead of +=1? I have an array that is organized with alternating "data" and "flag" values...
125
Hi i would like to ask! Im using Omron CP1E PLC May i know how to use one input to trigger two outputs alternatively? Meaning press X0 on, Y0...
397
I have several Avery scale units and they are configured as Generic Ethernet modules, and I am actually reading the data fine for the weight...
414
Has anyone had success communicating between the Avery ZM series of weight indicators and Omron CJ PLCs? I can easily do setups when provided...
313
