Lauer, it's a HMI or IPC?
ckchew666
Aug 2003
Malaysia
591
Hi all,
I've come across a plant which is using Lauer PCS 9000 (not sure it's a HMI or Industrial PC), has anyone come across this before? Can I replace it with a normal HMI instead? I do not know if this is known as PCS9000 or PCS9100 or PCS 8100, as I can see many models behind.
Currently there is a BIG dead spot on the screen already.
This Lauer is communicating with a Siemens S5 PLC.
Indudstrial PC from manufacturer Balluff.
UK address below, German company not sure which countries they have offices in.
Balluff Ltd
The Automation Centre, Finney Lane, Heald Green, Cheadle, Cheshire SK8 3DF
Tel: 0161 282 4740
Classification:
http://www.lauer-systeme.net/sides/pcs/pcs_e.htm
It appears that PCS9000 was a dedicated HMI panel.
It says "PCS9000 / PCS9100 not avaliable" on the page I linked to above ! It has probably been declared obsolete.
If I were you, I would contact Lauer and ask them how to upgrade to a newer panel.
But I am afraid that they will ask you to supply the original project file for the HMI program running on the panel. If you dont have it, contact the supplier of the machine and ask them for it.
II have to upload the program from a Lauer PCS090 HMI. I have searched here and Google for the software (I found the cable pinout) but every link...
6,840
Does anybody have a instruction manual for the Lauer 595 HMI? I have the software and I am having issues connecting. Any information on these...
2,228
I am looking for information/documentation on this obsolete LAUER unit. We have a machine on stop due to a fault with the display on this...
5,788
I dont have connection with this panel. Please help me. Can anybody worked for whis panel? I try connect the rs232-usb cable on the foto, but...
1,169
Hello everyone, help with information documentation for 2 line display LCA 400. Couldn't find anything on the internet about this model. When the...
1,622
