Exporting DeviceNet Input/Output tables
phuz
Jun 2008
Mohnton, PA
1,044
Aside from the "Export I/O Details" option when you right click on the DeviceNet scanner, is there a way to do a full export that would include the Input/Output tables and their mapping? I am trying to build a cross-reference for a PLC5 to a CLX conversion and having that mapping to compare to the new mapping would be great.
From the File menu, select "Generate Report".
The output is an HTML file with the Scanlist summary and mapping, as well as parameter lists for all the devices.
I had tried that, but it doesn't really provide much. Doesn't have the input/output mapping tables.
It shows this:
Input Memory
Discrete
Nothing Mapped
Block Xfer 62
Memory Offset Bit Length Node Message Type
N39:1.0 368 03, 1794-ADN DeviceNet Flex... Polled
...but that doesn't really give you anything. I was hoping for something like what you see when you click on the Input/Output tabs, where you can drill into each IO module.
Looks like I'll be doing this manually. :D
I am very familiar with Studio 5000 PLC programming. And I'm very familiar with C-More HMI programming. But this is my first time using a C-More...
302
As the title says, I'm trying to figure out a way to import and export recipe files from an external CF card to a USB drive and vice versa. I've...
483
Can anyone tell me how to export tags from PC Worx to a .csv file?
322
Hello Everyone, Happy 4th of July to my neighbors! Is there a way to edit Alarms in Excel? The native export is XML, and there is always...
769
I am working on trying to send and receive lists of BadgeIDs and User Access levels from a windows application to my system. My current theory is...
614
