1769-L35E Firmware Update
Hal9000
Jun 2010
London
140
Hi there,
I have a 1769-L35E cpu that I need to make program changes to. It’s running an old firmware version (12.12). I’d like to update the firmware version to say v20 so that I can use of AOI’s etc.
Can I make such a big firmware step up in one hit? I know that a new CPU is installed with version 1.xx firmware, so I presume I can?
Best regards,
Hi there,
Best regards,
You can. The flash tool will apply the upgrade in stages.
Just to reaffirm...
Yes, you can go straight from revision 12 to revision 20 firmware. If you are at revision 11 or earlier then you must first go to revision 12 or 13 before going higher.
Yes, revision 20 is the highest firmware revision that the 1769-L35E CompactLogix controller supports.
Yes, revision 20.019 firmware is the latest available for either Series A or B 1769-L35E controllers.
Also, see here for more info on potential issues when upgrading from older to newer revisions...
52503 - Issues Upgrading ControlLogix® Firmware Version
Access Level: TechConnect
I know that the change in date and time handling after version 16 has caught plenty of folks out in the past, including myself.
Regards,
George
Hello, I've recently updated one of our L35E/A firmware from v13 to v19. I get the warning of: (References changed @v16 I think) Warning: Line...
3,386
Due to a UCP power failure my 1769-L35E CPU has been inadvertently killed during the firmware update process. (don't laugh - it's not funny)...
2,895
Hello, We have had a machine running for the last 10 years. It has 2 x Kinetix 300 drives. Around a year ago, one of the drives failed. We were...
419
Hi, I recently tried to change the IP address of my 1769-L35E Series A, since doing this the MS indicator is flashing red and the NS indicator is...
928
Good morning guys. Im triying to communicate 4 JXC91 with a 1769-L35E AB CPU. I already test the JXC91 with a newer AB CPU using eds files and...
1,444
