Technology Objects in TIA Portal... Positioning
Pto
The thing is,
Today I was testing with Technology Objects and I received from SIemens guidelines for doing this with PTO. I have a S71211 CPU and a G120S-PN-Vector. This is different than the method we are discussing here offcourse. The thing is I have a Servo with driveCLQ connected to the G120 and All is connected. The Technology Object works and sends out pulses on Q0.1 and Q0.1. The main thing is, how do I have to configure the G120... Actually I think this drive can't do this, but I'm not sure. How to read in those signals... I mean, the drive needs stepper inputs to handle this I guess...
So basically I think both methods are not possible at this moment. PTO method is the important one for me as this is my testcase from Siemens.
DO you know if a G120 can read stepper inputs ?
And if so, how to configure this in the drive... didnt found it via the commisioning wizard...
Kind regards,
Gerry
I'm not very familiar with HSQ RTUs so I need some help if anyone can give it. I have an RTU that keeps cycling off to where I have to cycle the...
521
when controlling a closed loop stepper motor with a PLC,the PLC doesn't know if the target position is reached or not unless the driver it selfe...
988
Hi guys.Can somebody explain me or give me a practical example what is the fail-safe technology/signals . For what i read it is force plant into...
2,528
Good Afternoon , We had a rough summer with power outages , and I am always looking for a stable UPS system that would " ride us through" an...
1,765
Hi, I have two questions regarding the above software: 1. Does anyone have a simple method for converting the data type LREAL (used in this...
1,710
