AB Micro 820 Controlling 525 Drive
aandjsam
Sep 2016
lincolnshire
30
Hi all,
I've been handed over a project for a simple conveyor control system, what I've been given is a Micro 820 PLC and 3 AB 525 Drives, I've been asked to control them via an un-managed switch through Ethernet.
I was wondering if this was possible and if so, which function block is used to communicate with the drive?
Thanks in advance,
Sam
Yes it can be done, I do believe you can download from their support website the function blocks that you would need.
Really should not be that big of a deal. I have never used a 525 drive but I have used a micro820 communicating with a Schneider ATV630 thru Modbus/TCP.
I’m running a micro 820 to measure a tank level, then turning on equipment at certain levels. I have an analog input (4-20) that I’m storing and...
274
Hi All, I came up with this for ramping the PWM pin on the micro 820. I'm new to ladder logic so I am not sure if this will even work? Once...
343
The micro 820 is visible in RS Who when I configure my Ethernet to capture the random IP. I am getting an error when following the steps below...
939
Hi! I need help converting an old MicroLogix 1100 project to Micro 820. Project Details I have an old MicroLogix 1100 program that has been in...
466
