Mitsubishi Fx3U-64M+Fx2N-64MR
Demontager
Jun 2011
Kherson
I got a question regarding Fx3U-64M and Fx2N-64MR PLCs controllers.
The situation is as followed:
I'm working at ship and it has Bow Thruster and Stern Thruster and these thrusters have above mentioned PLCs. Once old one PLC Fx2N-64MR was damaged by salt water and it was on Bow Thruster.
Without a spare PLC i just removed working PLC from Stern Thruster and installed it to Bow Thruster.
Then my company sent a new PLC as they said new model- Fx3U-64, and I have installed it to Stern Thruster, but the problem is - I don't have a logic algorithm for Fx3U-64, EEPROM is new and without any logic, so i need to program it. But working logic still exists in old module Fx2N-64MR which is installed in Bow Thruster, so i planned just copy its EEPROM information and put to Fx3U-64M's EEPROM. Is it possible ?
I'm confused because of
EEPROM modules for FX2N-64MR and FX3U-64M are not same, anyway is it possible to copy working algorithm from one to another ?
http://6g6.eu/sih-memorycable is EEPROM for FX3U-64M
http://6g6.eu/sih-bow-thrustereeprom is EEPROM for
FX2N-64MR
I got a USB cable an adaptor, but not sure if it fit http://6g6.eu/sih-cableadapter
I'm in doubt because have already contacted one guy from Mitsubishi tech support and he replied i need "SC09N programing cable", but what for is mine "Mitsubishi FX-USB-AW" ?
This is a system general arrangement for Bow Thruster
http://6g6.eu/sih-bow-thuster-arrangement
and for Stern Thruster are completely the same.
Buy or arrange SC09N cable(if the laptop not having serial port u need usb to serial converter),GX developer software,upload the program and download in new plc
For the FX2N-64MR you will need the Mitsubishi SC09 cable, you could use the mini USB cable you have for the FX3U-64M but you can also use the SC09. When you open the PLC program in GX developer you will need to change the plc type shown below to FX3 CPU. You will then be able to download the program to the new plc.
Ok clear, but why i need only SC09 for FX2N-64MR? I checked its connection port and it same as FX3U-64M has.
BTW: How SC09 looks like ?
The SC09 looks like this...
But if the FX2 has the mini USB port then you could use the cable you have. Just go to the GX developer menu bar, find the online tab > Transfer setup and you can change the connection to USB.
James
the com cable you have are same as SC09..diffrent was the 1 you have on hand are using USB port and the SCO8 are using com port which are rs232 port..
as by muttleydoo..once you open ur GX developer you change the plc type than you may copy the FX2 ladder to the FX3 PLC..than you could download to FX3..but before you do that i would suggest you sumilate the program before you download ..make sure all the timer .bit and output are same as well.
Bonjour, Je n'ai pas de communication modbus RTU vis la configuration ci-dessus. J'ai essayé les deux mode ch1 et ch2 mais rien ne fonctionne...
186
Hello everyone; I have Mitsubishi PLC FX3U 32M in hydropower plant governor, an error message popped up when a technician was working on an...
405
hmi keeps saying "insufficient sensor failed" after the machine runs for 60 seconds. its a fx3u-48m PLC. The plc is not giving any errors or...
2,302
Hello All, I have been trolling through the Proface documentation to find an answer, but I read conflicting information. We have a...
3,965
Hi All, I am looking to install a Red Lion CR3000 HMI and connect it to a Mitsubishi FX3u 64M PLC via Serial. I cannot find confirmation on...
2,876
