Replacing a 1746-SDN
Apr 2002
Just a bit northeast of nowhere
1,117
Hi guys,
I am getting a spare 1747-SDN devicenet scanner card as spare parts for an older machine. I've never had to tinker with Devicenet on this thing - in fact, I'm still using RSLogix500 7.10 (CPR7) - so my question is this:
After reading some confusing posts at various forums, if the existing card fails, can I swap this thing directly, or does it need to be configured with RSnetworx after replacement?
Thanks,
TM
Yep, but you're going to need RsNetworx for Devicenet. Essentially you will go online w/ the existing network and grab the scanlist into a project.
As a sidenote, If you have controlnet or devicenet, make sure you have backups for these as otherwise you have to rebuild the configs in the event of failures and that can SUCK.
I have a plc @-20 in my factory where i cannot anymore upload the ladder program . . I Have in front of me a plc 2-30 .. Can i replace it ...
100
After replacing the 70 with the 525, the PLC can read from the drive and recognizes it as online, but no commands are being listened to. PLC is...
552
Hello all, It's been a while but have an odd request. Have a customer that has a AB SLC5/05 with a SDN module. On the network are several...
1,170
Has anyone ever replaced a touch screen on a legacy Red Lion G3 series HMI?
1,454
I have a processer that stopped functioning L32E. The only spare available is an Compact L33ER. Are these processers compatible? The IO is...
2,221
