Tia Portal v14 Embed Tag Value in Text List Item
Adam13
Feb 2008
Athens, GA
16
Using Tia Portal v14 and a KTP400 Basic PN, is there a way to embed a tag value into a text list item? I would like to create a selection list using a Symbolic I/O Field but I need the strings in the text list to update based on current tag values on the PLC.
Thank you!
If you are in edit field "Text" for the text list, you can right click there and in the context menu select "Insert parameter field". A dialog field pops up where you can select the Tag to insert and the data format.
The tag you insert there I'd configure to Aquisition mode continuous. I remember that otherwise it not always got refreshed in the textlist field.
Hopefully that works also with the Basic panels, I've used a comfort Panel.
Thomas, thank you for the quick feedback. Unfortunately that option does not appear when I right click in the text field. Doing some searching and I found a reference to using the format <Tag : 4, TagNameHere> to embed tag values (4 refers to # of digits). This does not work either so I have to assume tag embedding is not possible on the basic panels.
When editing Alarm text, right clicking does present the option "Insert tag field...". Unless I am missing something the text list function seems to be purposefully gimped in the basic panels. I would have thought this a "basic" function.
Text list right click image
Just tested it, it seems that it's not possible with a Basic Panel. Even not with the newer ones with V14 firmware like KTP700 Basic.
You must be really careful when selecting the basic panels, these things are really gimped as you say.
I had a project where I had to replace an absolute basic text based WinCC flexible panel which was used only for alarming. But the basic panels can't handle the number of alarms the old cheap one had supported.
Hi everyone. Please help me to upload program from S7-1200 with TIA v14. I created new project, go to Online tab, select Upload devices as new...
1,082
I am beatin gmy head against the wall trying to get my modbus comms working. I have a s7-1200 running tia v14, a cm-1241 comm card. I have...
22
7,401
I am trying to commission a compressor that is using a s7-1200 to communicate rs485/modbus to a the compressor interface. My rs485 module is a...
1,698
Is it possible to install Siemens Tia Portal V14 on a machine that already has V16 installed? Or do I need to create a virtual machine to install...
17
8,886
Is anyone know how to change the state of Button and multistate indicator(for Verify changing in color and text) in TIA portal HMI while doing...
1,320
