F-DI8 Diagnosis Word (6ES72266BA320XB0)
504bloke
Jan 2005
Down South
2,721
Can anyone point me to where it explains the what each bit is in the Byte for Diagnosis of the F-DI8 module, having read and searched the Failsafe Manual I cant find this info - or I am getting old and going blind :whistle:
I don't think your image came through, to see what you're showing.
Is the byte in the F-IO DB?
Hmmm
Yes its in
Program Blocks > Systems Blocks > Step7 Safety > F-IO Data Blocks and is then labelled in there as the DB - F00020_F-DI8/16x24VDC_1
I re-did a machine for a customer, which had Yaskawa MP2300Siec w/ 5-axis and Phoenix Contact Ethernet/IP I/O. According to the drawing and the...
1,805
Has anyone knowledge of CanOpen diagnosis tools-software. I found this of Helholz : https://www.helmholz-benelux.eu/product/can-bus-tester-2/ I...
966
My Siemens Step 7 education progressed today. I'm getting more familiar with how it all works, but at the end of the day I got stuck trying to...
1,018
I'm trying to use the DIAG_GET (or something similar) function block to detect an error on an AI563 (Analog TC module). The error is class 4, a TC...
3,157
Dear All, I have attached the hardware configuration of the system. My intention is to generate the alarm in scada when ethernet cable...
2,049
