grischa21 Member G Join Date Feb 2016 Location Essen Posts 1 Feb 28, 2016 #1 I want to read variables from the PLC with my C# programm. Is it possible to run my c# programm on a computer without the TwinCat System Manager to install (and from there select the route)?
ndzied1 Lifetime Supporting Member Join Date Aug 2002 Location Chicago, Illinois Posts 2,857 Feb 28, 2016 #2 I know nothing about Bekhoff but a quick google search makes it seem like you only need the right dll file to achieve this
Archie Member A Join Date May 2002 Location Orangeburg, SC Posts 1,944 Feb 28, 2016 #3 AdvancedHMI has a TwinCAT driver that does not require TwinCAT to be installed. The base solution is VB, but you can add a C# project to the Solution if you desire to write code.
