RAE300.msi / E300 Ethernet Module Rockwell software
golftmd13
Feb 2018
Missouri
Does anyone know about this RAE300.msi file needed for Studio 5000 to use an Ethernet module in the I/O configuration? I looked and ran the setup and it said the E300 module was installed but I still get the notification that RAE300.msi needs installed.
I am having a similar issue where i try to add the module onto a L82E embedded network and Studio5000 prompts a message saying that the AOP is unavailable and goes looking for it in a file "RAE300.msi". This installer cant find the MSI file even though the source path is pointed to the "RAE300.msi" file downloaded from the RA downloads site. Whats more annoying is the installer loops forever, restarting the search for RAE300.msi even when you try to cancel.
I've also tried installing the AOP from the application file (MPSetup) that comes with the AOP download. This doesnt work for me either.
My coworker was able to install the AOP into v21 then update to v31 with the modules showing in the controller organizer but the installer loop thing happens still.
golftmd13,
Were you able to figure anything out?
This has been really frustrating for us as well. I went through all sorts of steps to try to resolve this. I did repair installs on Logix, uninstall/reinstall of the AOP. All to no avail.
We ended up using the info from Tech Note 1071083 to remove the AOP and then get it installed (as Administrator) and eventually got it working. Why this was necessary to even have to do I cannot explain.
OG
HELLO ALL, Please can anyone help me to find the download file for RAE300.msi for rockwell plc many thanks in advance
1,918
Hi, I'm using E300 as E3 Plus in emulation mode. E300 is Rockwell Automation's overload relay. But I get hardware fault when I enable Ground...
456
When E300 powered off, the ethernet device tag data stayed at last know state, for example, fault bit is still Off, ready bit is still ON, status...
1,003
Hi everyone, I have So many E300 Control module kept dead due to Module status fault. I am trying to flash them to higher version from lower...
391
Hello, How do I go about adding an e300 to a motor greater than 200A. I have no problem adding it to any other motor less than that. Thanks!
1,094
