Logix5000 AOI vs Data types?
jimdi4
Aug 2004
108
Hello,
I was wondering if this was ever covered in previous threads:
I am new to AOI's (Add On Instructions) and to Data types. I usually just code straight forward logic.
I would like to use either an AOI or Data type to create control for a control valve, that will be standardized across many machines.
Can anyone give preference to either and AOI or Data type? Advantages? disadvantages? between the two...that would be great...
Jim:geek:
You are actually talking about two different but similar things.
The concept for the UDT and the AOI is similar. In each case you are building a template. In the case of the UDT - for a new composite data type. In the case of an AOI - for a logic procedure.
Ine each case, to actually use the template you have created you make a new tag (UDT) of you new type or create a new instance of the AOI which gets its own memory space and local tags.
So it's not so much a 'preference' as which do you use for a given purpose.
Thanks Bernie....I have a similar question on two seperate COntrologix open sessions.
One session I copied an ACD from our server that contained the Add On Instruction, and I have another Contrologix session open that doesn't have an add on instruction in the controller organizer.
Is there something I have to flip on to view the add on instruction in the controller organizer if its not there?
I guess another way of putting it, I want to copy the AOI from one Contrologix program to another...I see where you can export the instruction as an *.L5X but how do I then import it to another program?
Hello, I am trying to streamline an AOI that will get module/controller statuses from ethernet IO tree. Everythings fine, however, does anyone...
16
1,530
How do I call an AOI from an ST routine? I have tags made for the AOIs in my Controller Tags group, but how do I call the AOI in a Structured...
1,783
Hi all, I've been trying to get Modbus TCP to communicate (read only) with the Modbus TCP AOI that Rockwell provides, but I'm having issues and...
2,096
I am trying to create a simple AOI that takes in a standard compound data type and a number (as either an INT or STRING, whichever is more...
2,912
I've got a question for those of you with Ignition experience: I've been interested in Ignition for a few years now, have not had a chance to use...
1,828
