Help with DXG-NET device Net Card
sparkytex
Jun 2013
Port Hardy B.C.
354
Hey guys,
Has anyone set up a DXG-Net Device net card for an eaton DG1 VFD? In our WWTP the old eaton VFD failed and we had to replace it with a newer model because of course the old model was no longer available. We have to use a DXG-Net card so the AB compact Logix Processor could talk with the eaton VFD in remote mode.
MY questions are;
What should I set the MAD ID as on the eaton VFD?
What should I set the Baude Rate, is it supposed to match the AB PLC (19200)
Since the programming is already complete in the AB PLC as far as the run command, reference, running FB, CTRL from net, I imagine I just have to find the right assembly file that matches what the PLC is set up for?
any help with this would be greatly appreciated.
regards,
Tex
Hello everyone. Could someone please assist me? I am using Citect version 7.2 service pack 5 and Windows 7. I have created a project...
69
Hello, I'm not sure if anyone can help me. I made a big mistake by pulling out the battery to swap it with the machine turned off, and as a...
54
116
Hi Everyone, I own a GE Versamax controller that I purchased for a class at Long Beach City College a couple of years ago. I lost the use of my...
251
181
