Siemens S120 Servo Drvie Cylinder Flowrate Control Questions
Nan
Jul 2015
louisville
126
Hi Everyone,
I am new to siemens servo drives, needs some helps and wondering if you can help me.
The machine has Siemens S120 Servo Drvie and siemens motor, the motor mounted on top of a Cylinder, and move the cylinder up and down, when the cylinder goes up, it sucks material from the tank, when it is going down, it supply flow out, so it controls the flow rate.
Here is some information about the servo setup
The signal-level for the pulses is 5V DC, from the siemens TM 41 modul.
The gear ratio is I: 11,38 , you get 256 pulses per motor revolution.
28980 impulses per liter
I think I can use the formula and PID to control the speed of the servo, and get whatever flowrate I put in there right right?
Grams_per_Impulse = (1/ (IN_HMI_Flow_Meter_Impulses_Per_Liter/ 1000)) *(IN_HMI_Material_Density/1000)
OUT_PID_Grams_per_Second = (IN_Impulses_per_Second*Grams_per_Impulse)/100
Thank you very much!
As long as you stay inside the torque/power limits of the motor/drive then the drive speed loop controller will maintain the motor speed.
Hi all, I am having a machine with old 802d sl siemens controller. I am trying to tune servo by Siemens starter software. Anyone experienced...
67
I am using an S120 Servo with Telegrams 30,105, and 750. This is all working. The question is how do I get the motor temperature (Parameter r35)...
1,607
Hi, I'm programming an S120 servo indexer with s7 classic and wondering if the best way of doing this is with Easypos? Or is there something...
1,972
Kindly, has anyone tried to control Lenze servomotors with Siemens S120 drives ? Any special hints ? Have some concerns for the resolver and servo...
228
Kindly, can we install new Siemens Sinamics S120 motor modules and new 1FK7 servomotors, in place of old types ? Will the old motion control...
1,115
