Versamax Micro Serial programming Cable
rbz
Sep 2008
mexico
22
Hello
I need to connect to a GE versamax Micro IC200UDD120 through RS-232 serial port 1 (RJ45) to program it. Does anyone knows the cable pinout (rj45 to db9 female) so I can make the cable?
Taken from GFK-1645C, pages 9-24 & 9-25.
DB9 RJ45
1 n/c
2 ----------- 4
3 ----------- 3
4 ----------- 5
5 ----------- 8
6 ----------- 6
7 ----------- 2
8 ----------- 1
9 ----------- 7
Pin 8 on the RJ45 port is the pin closest to the top of the PLC.
I have a project where we specified a UDR003 Micro with an analog expansion unit. The RS-232 port was intended to communicate to a wireless router...
2,244
I'm trying to devise a serial communications heartbeat for a GE Versamax micro IC200UAL006. Is there some internal system bit that I can examine...
2,670
I do have a problem with a GE Versamax micro PLC. By going online (on Port 1) the "OK led" goes down. Power led stays On Port 2 no reaction at...
387
Hi, I am trying to set the IP address on the IC200UEM001 Ethernet Option Module. I am following the procedure in the manual for setting a...
428
Can anyone help me getting this comms connection set up? I am using Port 2 on the Versamax ICU200UDR005-DK, set in SNP with port settings Baud...
1,544
