Getting Started with Red Lion G306K
rmb550
Nov 2009
Ontario
86
I am struggling with getting this thing started.
I have installed Crimson 3.0 to a laptop and have connected a USB to RS232 converter that works perfectly with another device.
I think I need confirmation of pinouts to make a cable that will go from the converter to the HMI.
The existing device used the following pins:
Converter Pin1 >> Jump to Converter Pin4
Converter Pin2 >> Device Pin 3
Converter Pin3 >> Device Pin 2
Converter Pin4 >> Jump to Converter Pin 1 & Converter Pin 6
Converter Pin5 >> Device Pin 5
Converter Pin6 >> Jump to Converter Pin 4
Converter Pin7 >> Jump to Converter Pin 8
Converter Pin8 >> Jump to Converter Pin 7 and Device Pin 8
Converter Pin9 >> No Connection
I also need some guidance as to which port I should use.
Thanks,
rmb
On page 3 of the G306K manual (LINK), it shows the pinouts for the ports. Try making up a cable with 2 DB-9 female connectors to go from your converter to the G306K, and wire it like this:
Converter Pin2 >> G306K Pin7
Converter Pin3 >> G306K Pin8
Converter Pin5 >> G306K Pin5
You want to use the 'Programming Port' on the G306K
-Eric
Eric,
Thanks for this -- that is what I made -- but I have no idea how to find out if the device is communicating with my PC.....
rmb
I have the ALM & COM LED's flashing at a very high rate.
When I turn on DIP switches 1 & 2 and cycle the power, nothing changes.
Do I have a DOA HMI??
rmb
Hi Reading Hugh Jacks PLC book I would like to have a try with structured text, but I'm not sure where in RSLogix 500 I'm supposed to write all...
7,700
Hello all, this is my first time working with a PLC and dealing with hardware, so please have patience with me. I have an electric rod-style...
21
3,008
Hey Guys, First post here and looking through, there are a lot of people that have different expierences and practices. A little bit of my...
2,026
Hey Guys, I have plenty of experience with AB plcs . What is a good starting point to learn about fanuc robot programming. How to get started? Is...
2,698
Hello guys, the company I work for has always worked with Allen Bradley, except for small applications with Siemens, which we would now like to...
16
4,686
