1784-PCM5/B pinout? on the DB9, DH+
geniusintraining
Jun 2005
SC
8,274
Hello everyone... I have lost my adapter/pig tail that I plug into the DB9 and now I can not find the pinout and have look...
I have a PCM5/B on the end it has the removable round end for the DH+, I made an adapter (short pig tail) that plug into the DB9 and had 3 wires hanging out (data+, data- and the shield) I would hard wire into the trunk line (or at the CPU) and get into all the nodes for this connection
Does anyone know the pin out of the DB9?
From the Knowledgebase, article ID # 19500:
1784-PCM5:(this is the DH+ connection, comes also with mini-din adapter)
9 Pin D-Sub connector:
Wire Color Pin Number
CLEAR PIN 1
BLUE PIN 5
DRAIN(UNINSULATED) PIN 7
That adapter is part number 1784-CP7; most distributors and A-B offices have several stashed in a drawer if you need one.
I have the CP7 I just needed the drawing so I can hook up to my drop...
Thank you very much!
Mark
I would also be interested in the pinout of the DB-9.
I had the adaptor connected to the cable and it got bent in my bag and pulled the end out of the DB-9. I need to re-solder it on.
Regards Alan Case
Hi Alan,
I used the pinout that Ken posted and it worked perfect...
But not sure of the other side of the DB9 (this is what I think you are talking about) I just needed the pin out after the DB9 to the DH+
How many wires? they are only using the 3 wires, pins 1,5 and 7
I am looking for an RS232 to DH+ adapter.. Small
preferably something similar to 1761-NET-AIC
thanks
See links below, one is for a USB to DH+ the other two are RS232 to DH+.
But nothing similar to the AIC.
Make sure you are sitting down before looking at the prices.
http://samplecode.rockwellautomation.com/idc/groups/literature/documents/in/1784-in045_-en-p.pdf
http://www.industrial-gateways.com/DL3500-RS232-422-485-and-USB-Interface-to-A-B's-DH-plus-or-DH-485
http://www.ebay.com/sch/i.html?_nkw...d=1770-kf2&geo_id=10232&adgroup_id=3617907036
I currently use a 1784 card to comunicate to my slc 500.I am about to upgrade computers and need to upgrade to a usb cable which cable do i need...
1,938
Could anyone know how to Convert A-B 1784-PCM2 (SER:A!) TO 1784-PCM5?(spent little money) I have an old 1784-PCMK card (ser:A) and 1784-PCM2...
1,772
I have an allen bradley 1784-PCM5 cable and i can not see to find any info on what it goes to. I have foud a lot of info on 1784-PBM5/B but my...
3,263
I am curious, I have not done this yet.....I may fry my stuff... Can I connect my 1784-PCM5 cable (DH+ cable with a D-SUB 9 pin coupled with a...
6,446
Hello, I have a 1784-U2DN, and I have a flashing red light on the module status LED. Manual says I have a recoverable fault….but it doesnt say...
905
