Din Rail Mount Toggle Switch
dollivier
Aug 2002
Does anyone know of a manufacturer that makes a DIN rail mount toggle switch? We need to provide a simple digital input that we want to keep inside the panel (away from happy fingers) and a DIN mount would be ideal for ease of installation.
Dennis
No, but you might be able to build something using a Universal 'empty' module from Phoenix Contact. They make empty module housings that are DIN rail mounted. I think the model series is 'UEGM'. Try Weidmuller as well.
Allen-Bradely is the manufacturer. I oredered it from McMaster-Carr. Its good for 28VDC/2A or 120VAC/2A. The one I ordered is a on-off-on SPDT. McMaster-Carr part number is 7218K11. Cost is $23.37. Allen-Bradely part number is 1492-WD4P.
DIN Toggle Switch
The reason for the toggle: We have 2 available Modbus ports on the PLC. One is used to communicate via radio-modem to a SCADA computer running Wonderware. The other is used to communicate to a VFD to transfer a number of parameters / values to and from the PLC. To modify/troubleshoot using a laptop requires disconnecting the VFD communications. Since the PLC acts as the Modbus Master to the VFD and needs to be a Modbus Slave to the Laptop we will use the toggle switch to disable the transmit functions from the PLC when we must communicate with the laptop. A third Modbus port would be a great solution but this PLC, a Momentum, will not support a third Modbus port, per the factory tech support.
I am looking for a fiber-to-copper media converter that is 120 VAC powered with terminals for placement in a small panel, so I can't use the wall...
130
I have to mount a lot of slotted din rail and just ordered today. What is the best type and size of screw to use? Course or fine thread? I am...
20
2,438
Just wanted to check and see if anyone can suggest an image storage method for vision systems. I have done some of this before with FTP to a...
4,223
I thought I could easily find a previous thread where someone had used an adapter to mount an S7-300 CPU on a standrd 35 mm DIN rail, in stead of...
5,668
After a lot of web surfing the other day i found this...
6,749
