Simatic Manager
bleach
Jul 2007
Jeddah
61
I am having a problem in installing SIMATIC MANAGER v. 5.3. Before, in my PC I had v. 5.4 and I uninstall it. Now when I try to install v. 5.3 it brings me an error message which is (string variable is not large enough for for string. Check the string declaration, Error 401), and it never continue installation. How I can solve this problem.
I had the same problem last year. Siemens offical answer was to reformat the HD and reinstall everything, however I found that if I searched every s7... registry entry and deleted it and made sure all s7 related files were deleted I was able to roll back to V5.3 from V5.4. Be warned it took me several hours to complete this task, but it was easier than reinstalling everything from scratch. Transfer the licence key back to the original FD or a USB key before you start just in case.
Note this comes with a health/wealth warning:
Altering the registry and deleting system files can have unexpected effects so make sure anything important is backed up in case you end up having to reinstall from scratch
coooooooooool
sounds good, thank you guys, i tried that and what i understode from the website, i even must remove Win CC and Protool and all the software that related to siemens. i mean its a pain that i reinstall every things again. if there an easy way.
BEST REGARD
If I were in your position I would uninstall the simatic manager then I would use CCleaner to clean up the registry.. For some other re-installations this have worked for me..
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
306
Got a VIPA 315-2AG23 that i try to go online with but can't seem to make it work through a network. I can go online if i'm plugged directly in the...
258
Hello all. I went to a customers location, uploaded from the S7-300 (CPU312) and performed a save, performed some work then came back to the shop...
587
Hello.We are trying to convert a program written with S7-300 Simatic Manager to S7-1200 V16.Unfortunately, there is only LAD,FBD option in S7-1200...
745
Hi, I have recently gone full in on TIA after holding on to Simatic Manager. One thing which I find more difficult is the filter function for...
1,709
