Beijer HMI (Scripting)
phuz
Jun 2008
Mohnton, PA
1,043
First time working with one of these units. Software isn't too bad, but I'm a bit stuck on the scripting engine. The documentation isn't very helpful. Do the Script Modules constantly run or must they be called? This application has a "timer" script that gets set true with an interval of 1000, but I don't see the code being executed otherwise tag values should be increasing, and they are not. This application was handed to me as the "latest" from the original programmer.
It's c# and so event driven.
The script modules are not automatically called, but if you have a timer somewhere this may be calling the sm, or if it doesn't need to be instantiated then maybe just a method in the sm.
In the script module, on the left are events to which methods can be hooked; 'script module created' is a likely candidate for creating a timer event which repeatedly calls other stuff.
Pp
Pp
Actually under script module created, there is nothing. The timer is defined, however, within the script module. I just can't figure out what's calling the script.
I'd be happy to have a quick look. You can mail it if you'd rather not post it.
No problem with posting this:
(...and thank you:))
Code:
// Press F1 to get help about using script.
// To access an object that is not located in the current class, start the call with Globals.
// When using events and timers be cautious not to generate memoryleaks,
// please see the help for more information.
namespace Neo.ApplicationFramework.Generated
	using System.Windows.Forms;
	using System;
	using System.Drawing;
	using Neo.ApplicationFramework.Tools;
	using Neo.ApplicationFramework.Common.Graphics.Logic;
	using Neo.ApplicationFramework.Controls;
	using Neo.ApplicationFramework.Interfaces;
	public partial class TimerScript
		private static Timer timer1 = null;
		static TimerScript()
			timer1 = new Timer();
			timer1.Tick += new EventHandler(TimeOut1);
			timer1.Interval = 1000;
			timer1.Enabled = true;
		public void Stop()
			try {
				timer1.Enabled = false;
			catch(Exception) {}
			if (Globals.Tags.Running_Status.Value==1)
			{Globals.Tags.Paused.Value = 1;
			Globals.Tags.Elapsed_Time_Color.Value=0;
			else
			{Globals.Tags.Paused.Value = 0;
		public void Start()
			try {
				Globals.Tags.ElapsedTime.Value = 0;
				Globals.Tags.ElapsedTimeMin.Value = 0;
				Globals.Tags.Elapsed_Time_Color.Value=1;
			catch(Exception) {}
		public void Resume()
			try {
			catch(Exception) {}
		public void Reset()
			try {
			catch(Exception) {}
		private static void TimeOut1(Object myObject, EventArgs myEventArgs)
			{Globals.Tags.ElapsedTime.Value = Globals.Tags.ElapsedTime.Value + 1;
				Globals.Tags.ElapsedTimeMin.Value = Globals.Tags.ElapsedTime.Value / 60;
			if (Globals.Tags.Running_Status.Value==1 &&
					Globals.Tags.CookDone.Value ==0)
				{Globals.Tags.Step_Elapsed_Time.Value = Globals.Tags.ElapsedTimeMin.Value;
				Globals.Tags.ElapsedTimeMin.Value>=Globals.Tags.Cook_Time_1.Value &&
				Globals.Tags.Rec_Cook_Time_2.Value >0 &&
			{Globals.Tags.Cook_Done1.Value = 1;
			Globals.Tags.Step_Elapsed_Time.Value = (Globals.Tags.ElapsedTimeMin.Value-Globals.Tags.Rec_Cook_Time_1.Value);
				Globals.Tags.ElapsedTimeMin.Value>=Globals.Tags.Cook_Time_2.Value &&
				Globals.Tags.Rec_Cook_Time_3.Value >0 &&
			{Globals.Tags.Cook_Done2.Value = 1;
			Globals.Tags.Step_Elapsed_Time.Value = (Globals.Tags.ElapsedTimeMin.Value-Globals.Tags.Rec_Cook_Time_1.Value-Globals.Tags.Rec_Cook_Time_2.Value);
				Globals.Tags.ElapsedTimeMin.Value>=Globals.Tags.Cook_Time_3.Value &&
				Globals.Tags.Rec_Cook_Time_4.Value >0 &&
			{Globals.Tags.Cook_Done3.Value = 1;
			Globals.Tags.Step_Elapsed_Time.Value = (Globals.Tags.ElapsedTimeMin.Value-Globals.Tags.Rec_Cook_Time_1.Value-Globals.Tags.Rec_Cook_Time_2.Value-Globals.Tags.Rec_Cook_Time_3.Value);
				Globals.Tags.ElapsedTimeMin.Value>=Globals.Tags.Cook_Time_4.Value &&
				Globals.Tags.Rec_Cook_Time_5.Value >0 &&
			{Globals.Tags.Cook_Done4.Value = 1;
			Globals.Tags.Step_Elapsed_Time.Value = (Globals.Tags.ElapsedTimeMin.Value-Globals.Tags.Rec_Cook_Time_1.Value-Globals.Tags.Rec_Cook_Time_2.Value-Globals.Tags.Rec_Cook_Time_3.Value-Globals.Tags.Rec_Cook_Time_4.Value);
				Globals.Tags.ElapsedTimeMin.Value>=Globals.Tags.Cook_Time_5.Value)
			{Globals.Tags.CookDone.Value = 1;
		void TimerScript_Created(System.Object sender, System.EventArgs e)
The method called TimerScript() has the same name as the class, so it's a constructor. This'll be called automatically. The timer is created here and its Tick (done) is hooked to the Timeout1 method.
Note, some of the methods (Start, Stop, Resume etc) are defined Public, so I guess they're called from script behind screens. Look for 'Globals.TimerScript.Start();' syntax.
Tbh, looks like work that should've been done in the plc but that's my $0.02.
Pp
Edit...something's nagging me about constructors in a partial class. I'll have a quick look in the morning.
Pp
So the fact that it's enabled, it doesn't automatically start "ticking" ?
To me, this is different than a normal visual studio app.
I'll poke around for a start, but I cross referenced TimerScript before and nothing else came up. If it just needs the Start, I can easily do that in the main script.
I looked in every screen's script and there is no reference to the TimerScript.Start. But, since you said this gets called automatically, I would assume it get's enabled immediately upon loading, right? The declaration for timer1 includes a timer1.enabled so I would expect to see that going all the time.
None of the graphic screens have any custom scripting behind them, anyway.
Didn't realize you could do actions directly out of the tag database, but I found it. There is a bit being set in the main script which didn't cross reference to anything else, but I found this box at the very end, and voila!
Now I am confused about how the datalogging actually starts. I have it set to collect at periods of 5 seconds, and I have my trend set to use the logged values, but it doesn't start showing the graphs until I go to the trend page, and once I do that, it continues to collect.
Hello
That trigger was well hidden! Well found!
Trending...are the tags set to 'Always Active' in the tag list?
TBH, I thought tags reference in the datalogger had this applied regardless, but I could be wrong.
I confirmed the data logger is collecting data right away, but the graph is only showing data from the time I enter the trend.
hello every body. I want to upload program from E100 HMI Beijer. I have " E - Designer " software and CAB5 programing cable. I tried with USB to...
18
3,182
Hello, Maybe it is just a simple problem, but I cannot solve it. I have a Wago 750-881 connected to a Beier HMI through IP TCP, the connection is...
874
Well, I'm working with this ABB plc project, and It's been a learning experience coming from Allen Bradley. The project can't be changed to an AB...
1,142
Hello, Can somebody tell me how to Upload and Download program from Beijer 1071 Panel Operator/HMI to a CF Card directly without E-Designer, since...
1,431
Hi. I need to get an upload from a Cimrex 30 HMI. According to a label on the back, it's made by Beijer. See attached photos. It's successfully...
2,534
