Self Powered Remote Sensor
Geoff White
Oct 2005
Brisbane
461
We have a customer that wants to have a portable level sensor that can be moved between tanks and signal when the tank has dropped below a level.
To do this the sensor (probably a capacitive sensor clamped to a level tube) would need to be connected to a box that is providing both power for the sensor and wireless comms.
The remote box would need to be rechargeable.
I know there a numerous ways this could be built from various IOT boards but is there some real product in this niche?
Thanks guys.
The customer is a tightarse and wants a single portable sensor because they only use one tank at a time and have heaps of them. The tanks are in close proximity so cellular data is not needed.
The Digi looks nice but it uses non rechargable batteries that only last 2 years at 2 samples per day!
A typical 4-20mA transmitter will run for several days continuously on a triple 9V transistor battery (3 batteries wired in series) pack.
Banner node radios operate on a lithium D cell for a couple years and can be turned off with the faceplate pushbutton.
Find the correct type of 2 wire loop powered level transmitter (pressure, ultrasonic, radar, whatever), power that with relatively cheap 9V batteries that are easily replaced and a Banner node radio and gateway radio. Gateway radio is near whatever you're sending the level signal to and is 24Vdc powered.
That reminds me of a little tester I had that I got from a Banner rep. It was a small box with spring terminals and a DC micro plug and a couple of LEDs. You could plug in a photocell or prox switch and test it by looking at the LEDs. It ran off 3 9V batteries. I think they were available for sale and might make a good basis for the OP to build something.
https://www.alliedelec.com/product/banner-engineering/dbq5/70168288/
Another place to look:
https://www.onsetcomp.com/products/data-loggers/zw-008
https://www.onsetcomp.com/products/data-loggers/ux90-004
We used Hobo Loggers for temporary temperature monitoring at a food plant where I used to work. They are surprisingly robust and easy to use and relatively economical. We stuck them inside freezers as low as -40F. Ours were not the wireless type, we had to retrieve them and upload the data. Their tech support was good too, so you might call them with your application and see what they recommend.
If you are keen on the idea of building your own.
An Arduino with analog in, a 4-20mA level sensor (an ultrasonic sensor from Automation Direct), and a rechargeable battery could help your frugal friend. Then you could pull the data off the Arduino using WiFi over ModbusTCP.
You may even be able to mount the Arduino and battery on top of the level sensor in a small plastic box.
Battery life should be OK but read rates and sensor selection will determine battery life.
Made me wonder, who is moving around the sensor for free? :geek:
The sight lines are a tube running up the side of the tank. The sensor would only need to be clipped to tube at arms reach from the bottom of the tank.
It's not a stupid idea, just half arsed.
I am using Moore APACS/Quadlog PLC. The analog cards are Moore SAM (Standard Analog Module). The SAM accepts 4-20 mA DC two-wire transmitter...
10,012
Hello friends I think this is the second post about this all over the internet, first one was in 2013 by some guy from Canada who experienced the...
26
6,329
Hello; We have an Allen Bradley compact logic processor at an auto glue kitchen of corrugator machine which connected with AB HMI. Normally to...
2,419
Hello Friends, I'm starting a new job soon, towards the end of September, that will be using all Beckhoff equipment. I have programming...
1,027
Hi all, Any experience of the above? Happened 3 times now in 1.5 months. Processor is about 10 years old, software major revision is 19...
5,516
