Which Software do I use?
2rlp
Sep 2006
Mumbai
136
I have been tasked with modifying a system that uses the following
  • BMXP342020 PLC and
  • HMIGXU3512 HMI.
I gather they are made by Schnieder Electric. But am not aware of the software that is used on this make.
Please someone point me to the right softwares
Software packages below :)
BMXP342020 PLC - Unity Pro
HMIGXU3512 HMI. - Vijeo designer
Can you really pay to reprogram the machine from scratch instead of getting the programming tools ?
Fine, whatever. I don't know the scope of the machine or how well his customer wants it to work, or whether he's got an infinite time budget.
I agree it seems ridiculous..plus the cost of the replacement PLC/HMI combo
If I was the customer I would reject the extra downtime & risk associated with this 'reprogramming', sounds like the OP doesnt even have a reliable code backup to work with right now
I'm not even sure why the OP asked the question in the first place if the decision to jump to another manufacturer is that easy....
As i said, the software works fine in trial mode for a good few weeks.
Unity Pro S. One of the better ones I used. But you will most likely need to get the .sta or .xef copy if it was developed in an earlier version.
I have already done 5 similar projects on Delta. So yes the software has already been tried & tested. The said project was left incomplete by a Schnieder system house about 9 years back. All I need to do is to install the sensors as per my requirement and change the PLC to Delta. This will be much cheaper than purchasing Unity Pro
Hi! So my problem is a little funky, I had Studio 5000 v 24 and 30 installed, but forgot to install RSLogix (which I cannot go without). Is there...
112
90
Hi, I cannot find the DLCA1764.EXE utilty software for data retrieving. Can someone share the link to download this software. Thanks!
112
Hi everyone, I am an omron plc tec , lately I came across a siemens s7 200 cn plc . Can someone help me regarding the software required and...
26
497
Hi everyone, I'm in search of software for electrical drawings, preferably free but also interested in paid options. Any recommendations or...
33
1,560
